Page 2 of 2
Re: USB descriptors larger than 127 bytes don't work (STM32
Posted: Thu May 01, 2014 11:48 am
HI,
I committed an experimental fix in the *trunk*, could you confirm it solves your problem?
Posted: Thu May 01, 2014 5:46 pm
by avrhack
Giovanni wrote:HI,
Excellent Giovanni thanks. And yes I can confirm that it solves the problem on an STM32F4DISCOVERY with 2.6.3 at least.
Testing I did was to run it against the stable 2.6.3 snapshot (I add tags to your full git repo clone that I keep) and it worked <127, confirmed it failed >127 against 2.6.3. Applied the HLD patch and it worked, then removed that patch, confirmed it failed and then finally applied your LLD (which I made as a quick patch from diffs on your main trunk) and it worked again with a descriptor of length 141.
So I think that's a pretty conclusive test confirming that things fail against 2.6.3 and work with either the HLD patch or your new proper fix of the LLD.
Much appreciated!
Posted: Thu May 01, 2014 7:17 pm
Very well, I will merge the change in 2.6.4 and 3.0.0.
Posted: Thu May 01, 2014 8:46 pm
by avrhack
Giovanni wrote:Very well, I will merge the change in 2.6.4 and 3.0.0.
Excellent thanks!
Posted: Sat May 10, 2014 9:05 am
by etmatrix
@avrhack have you an example? I tring with branch 2.6.4 but with my dualcdc example I have an error.
usb 4-2.1: configuration #1 chosen from 1 choice
usb 4-2.1: can't set config #1, error -110
Single CDC is working without problem.
The error message is different from my previous thread viewtopic.php?f=3&t=699
Thank you
Posted: Sat May 10, 2014 10:11 am
by avrhack
etmatrix wrote:@avrhack have you an example? I tring with branch 2.6.4 but with my dualcdc example I have an error.
Thank you
I don't have a simple main.c I can send as it's got a whole load of other stuff in there, but I've attached the usb descriptor / callbacks which are a modified version of Giovani's original single-CDC demo. Hopefully if you compare with yours / plug these in you'll get it working. If not let me know and I'll try and hack up a main.c to go with it that is just the CDC parts :)
usbcfg.zip
(3.85 KiB) Downloaded 567 times
Posted: Sat May 10, 2014 10:58 am
by etmatrix
Thank you avrhack for your source, while I see the difference, I have found the problem. SDU2 is not initiliazed, so this make problem to usb init.
Posted: Sat May 10, 2014 11:56 am
by avrhack
etmatrix wrote:Thank you avrhack for your source, while I see the difference, I have found the problem. SDU2 is not initiliazed, so this make problem to usb init.
Excellent. And if it's any consolation I spent ages trying to figure out why things didn't work - the initialisation and order of that is particularly critical.
Great that you've got it working though as it gives a second confirmation to my testing of Giovani's fix in 2.6.4.
