MIPS32 port
ChibiOS public support forum for topics related to the micro-controllers based on MIPS32 cores.
Dmytro
Re: MIPS32 port
Post by Dmytro »
Few updates:
PIC32: PWM LLD
the PIC HW is a "bit" odd in terms that it does not generate interrupt on compare in PWM mode, so no such events supported
the other mode of Output Compare module is promising but I can't get expected output so I'll try to find an oscilloscope to continue with integration
PWM HAL: extend API with pwmChannelChangeWidth
Dmytro
Re: MIPS32 port
Post by Dmytro »
I2C LLD pushed, enjoy!
Re: MIPS32 port
Good job.
It is maturing so fast, after the 2.6.0 release we should discuss the details about merging with mainline.
Re: MIPS32 port
Nice work, twitter knows about it.
Dmytro
Re: MIPS32 port
Post by Dmytro »
Thanks guys.
I believe only few remaining things are there:
- ethernet(have some doubts whether anyone needs that)
- flash write(that's useful if there will be a chibi-boot at some point)
gera
Re: MIPS32 port
Post by gera »
what was the reason of swapping interrupt and data endpoints in your last change to usbcfg.c ?
I could not make the serial-over-USB work until I restored the definitions to match USB spec.
Dmytro
Re: MIPS32 port
Post by Dmytro »
thanks for pointing on that. In fact that was a typo. I have already submitted correction.
gera
Re: MIPS32 port
Post by gera »
Great, thanks. I am not very familiar with USB so I thought that it may be done in purpose which I don't understand.
gera
Re: MIPS32 port
Post by gera »
Some preliminary mac_lld code is available from http://code.google.com/p/ecos-pic32/dow ... p&can=2&q=
It currently runs on ESK (Ethernet Startup Kit) board.
Dmytro
Re: MIPS32 port
Post by Dmytro »
Cool!
Can you please do a pull request via github?
thanks,
-- dmytro
