Page 12 of 12
Re: ST-Link V2 on Linux/OSX/Windows
Posted: Thu Nov 28, 2013 11:00 am
by lazureus
Thanks a lot for advise, I already compile it, at the evening I'd try to test it with STM32F4-DISCOVERY, and with new toolchain maybe I'll start gdb with new toolchain.
Posted: Thu Nov 28, 2013 12:32 pm
by mobyfab
Hey,
I'm making a package for 13.10, it should be available within the hour. (being built by ppa bot)
Posted: Sun Dec 01, 2013 5:50 pm
by lazureus
Hey mobyfab,
I've build your qtlink and the saucy and it works quite nice :) I saw also that you make version for the 13.10, thanks for that. Nevertheless still I cannot debug my ChibiOS application with arm-none-eabi-gdb, during I did as follows:
- compile demo for ARMCM4-STM32F407-DISCOVERY
- flash device through qtstlink, everythinks works fine, including logs on UART after USER button press
- erase device through command st-flash erase
- run st-util in one terminal window
- run arm-none-eabi-gdb ./build/ch.elf
- run command target extended-remote localhost:4242
- run command load, loading was successful
- run command continue
- press CTRL+C, program seems to stop on the function called void _unhandled_exception(void) {} in the file ../../os/ports/GCC/ARMCMx/STM32F4xx/vectors.c
- trying to run command ni, has no effect.
Could you tell me did I do something wrong or where is the problem ? with toolchain ? I still use the old toolchain summon-arm-gcc, because I don't know actually how can I delete it, it installed for me the /home/$(USER)/sat directory but all executable files are in /usr/bin.
Posted: Mon Dec 02, 2013 3:28 pm
by mobyfab
You should give OpenOCD a try.
It used to work fine for me.
Also use this toolchain instead: https://launchpad.net/gcc-arm-embedded (ppa: https://launchpad.net/~terry.guo/+archi ... m-embedded)
Glad the new QStlink2 build works, thanks for testing.
Posted: Sun Sep 07, 2014 3:47 am
by cidadao
Is it possible to add support for STM32F107 micros?
Im currently using Olimex STM32 P107 development board and qstlink2 tells me "Device not found in database!"
Posted: Sun Sep 21, 2014 1:16 pm
by mobyfab
Yes,
I just need the chip ID. (in the datasheet)
