I2C implementation for STM32
Looks like no feedback for a moment.
Giovanni, can I perform merge to trunk, or only you can commit to trunk?
You can commit to trunk, please just change I2C related files, I am still moving STM32 stuff around.
Hm... It is better to postpone merging until STM32 code stop moving. Let me know when you are finished.
The I2C code would not be impacted, put the low level driver under ./os/hal/platforms/STM32 as usual.
DrunkenDonkey
Hey guys, I'm a few days reader on this forum, never ever touched embedded development before, still a week till my kit comes, but I have set some eclipse/G++ and using the time to fell in love with ChibiOS
I must say stuff looks kinda confusing from the start, but Chibi is a massive help, many thanks for it!
For good or bad, I started learning what i2c is first, checked the i2c source on that branch (great news about merging it to the trunk) and while I sorta understand how the stuff works from a hardware standpoint, I'm not sure about the current implementation... considering I will have a gadget that have... "registers" that I can read/write to, and I need access to several of them at once for a single operation, I considered the blocking approach:
#define HAL_USE_I2C TRUE
#define I2C_SUPPORTS_CALLBACKS FALSE
#define I2C_USE_WAIT TRUE
So I guess a code to write to a register will be:
But what will be the code to read from it since by i2c specs I have to "write" before reading... looking at the code transmit function is filling the structs, then some interrupt handler pokes with them, but I can't tell if after MasterTransmit operation the data will be already in the rx buffer, or do I need to do a separate reading, i.e. should I do:
Or the proper way to do is
I totally understand I'm asking very newbie questions, sorry for that
i2cAcquireBus(&I2CD1);
tx_data[0]=register;
tx_data[1]=data;
i2cMasterTransmit(&I2CD1,&i2cSlaveConfig,slave_addr,tx_data,2,rx_data,0);
i2cReleaseBus(&I2CD1);
//proceed to more transmit/receive
i2cMasterTransmit(&I2CD1,&i2cSlaveConfig,slave_addr,tx_data,1,rx_data,0);
i2cMasterReceive(&I2CD1,&i2cSlaveConfig,slave_addr,rx_data,2);
//do something with the data
i2cMasterTransmit(&I2CD1,&i2cSlaveConfig,slave_addr,tx_data,1,rx_data,2);
First of all, driver can not work without callback for a moment. So you must set
Your second way is proper.
But may be device specific. What your device is?
#define I2C_SUPPORTS_CALLBACKS TRUEYour second way is proper.
//do something with the dataBut may be device specific. What your device is?
DrunkenDonkey
Thanks for response barthess. I want to poke with iphone authentication chip, it have quite clean protocol. So, having callbacks on, is it possible the i2c driver to work synchronous, i.e. I2C_USE_WAIT still have an effect right, so I can leave the callbacks there feeling empty, but can still have multiple i2cMasterTransmit with/without receive one after another? That would be so great.
That's right. If not sure - you can switch mutual exclusion on and surround calls by i2cAcquireBus i2cReleaseBus clause.
I have a request. I originally requested a hook in I2CSlaveConfig because I wanted to store (changing) information about the slave devices that would be accessible in the callback functions. After much frustration I realised that this was causing me headaches because I2CDriver.id_slave_config is const I2CSlaveConfig. Could it be changed such that the two callback pointers in I2CSlaveConfig are const, but not the structure itself?
I can get around this restriction if we have a hook for extra fields in I2CDriver (this would probably be useful regardless), but as the information relates to the slave rather than the driver I don't think this is such an elegant solution
Technically this is not a problem and initially that pointer was not const. Const qualifier was set to save couple of bytes.
Check rev. 3306. Now it is not const.
UPDATE:
rev. 3307
UPDATE:
rev. 3307
