[DONE] The New STM32F429/F439
trepidacious
Re: [DONE] The New STM32F429/F439
Post by trepidacious »
In case anyone is interested, I had a chance to test the DCMI with concurrent SPI5 transfers - this should produce concurrent DMA on controller 2, and on the 40X would have triggered an errata and locked the MCU. On the 427 it seems fine, which is nice!
While testing this I noticed that in STM32F4xx/hal_lld.h in trunk, on line 489, SPI 4-6 are only enabled for 429 and 439, I tried changing the line from:
#ifdef STM32F429_439xx
to:
#if defined(STM32F427_437xx) || defined(STM32F429_439xx)
and tested on a 427 board with SPI5, this works fine.
Ben.
Thanks for reporting, I will add the change to the trunk and various branches.
inca
Post by inca »
I am having trouble getting 168 MHz to work with the board.chcfg. hal_lld.h fails with
../../chibios3/os/hal/ports/STM32/STM32F4xx/hal_lld.h:1087:2: error: #error "STM32_PLLVCO outside acceptable range (STM32_PLLVCO_MIN...STM32_PLLVCO_MAX)"
../../chibios3/os/hal/ports/STM32/STM32F4xx/hal_lld.h:1099:2: error: #error "STM32_PLLCLKOUT outside acceptable range (STM32_PLLOUT_MIN...STM32_PLLOUT_MAX)"
../../chibios3/os/hal/ports/STM32/STM32F4xx/hal_lld.h:1119:2: error: #error "STM32_SYSCLK above maximum rated frequency (STM32_SYSCLK_MAX)"
../../chibios3/os/hal/ports/STM32/STM32F4xx/hal_lld.h:1198:2: error: #error "STM32_HCLK exceeding maximum frequency (STM32_SYSCLK_MAX)"
../../chibios3/os/hal/ports/STM32/STM32F4xx/hal_lld.h:1222:2: error: #error "STM32_PCLK1 exceeding maximum frequency (STM32_PCLK1_MAX)"
../../chibios3/os/hal/ports/STM32/STM32F4xx/hal_lld.h:1246:2: error: #error "STM32_PCLK2 exceeding maximum frequency (STM32_PCLK2_MAX)"
Is this somehow due to the USB OTG? It doesn't seem to be, since there are no USB OTD errors and it's not enabled.
I copied the STM32F407 HAL example to use with a custom STM32F429 board. I don't see any other meaningful differences between the board.chcfg files of my project and the RT-STM32F429-DISCOVERY. FWIW, I tried defining STM32F429_439xx but it seems to fail before it even gets to those #ifdef checks.
Cheers,
inca
You should start from the F429 example. Those are problems with clock settings.
inca
Post by inca »
Sorry... I spaced and wasn't reading the variable names right. The clock is fine and at 168 MHz already. :roll:
