The RTC driver topic
Re: The RTC driver topic
I agree, there would be one implementation for each driver, but luckily most RTCs are of the calendar type, the STM32F1 is an exception apparently.
barthess
Post by barthess »
I propose to realize own code for "smart" MCUs and keep as is for F1x. Do you agree?
Let's address the F1 last, how would you modify the driver model?
The minimal functionality required is to support the FS, everything else can stay outside the driver.
barthess
Post by barthess »
Why driver model? Just add #ifdef STM32_RTC_IS_CALENDAR in rtcGetTimeFat() function.
barthess
Post by barthess »
Can we add compiler specific code in #ifdefs? For example,
localtime_r()
for gcc and
chSysLock(); localtime(); chSysUnlock();
for other compilers?
The problem is that some compilers don't support localtime() at all. This is why I wrote to support FAT time directly in the driver without dependencies, all conversions done inside directly from RTCTime to fattime.
rtcGetTimeFat() would be part of the driver interface, I don't really care about the other time formats like struct tm and Unix, that stuff brings in a lot of libraries including 64 bits integers.
Probably it is better to move rtcGetTimeTm(), rtcSetTimeTm() back into the driver and make them available only if the compiler supports time.h using a switch defined in the low level driver: RTC_SUPPORTS_TM.
rtcGetTimeFat() also moved in the driver and would always be available regardless the time.h support.
Unix time format is not required, it can stay external, it can be converted from the tm structure anyway so there is no reason to support it in the core OS.
saraben
Post by saraben »
Giovanni, Barthess,
For the STM32F1..., Martin Thomas has some compact time functions including fattime converrsion. Some of them are derived from other sources as noted in his comments. For the F2 where the RTC stores datetime in calander format fat time conversion is trival.
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/arm_memcards/index.html#chanfat_stm32
Note the following though. In rtc.c, counter_to_struct() has a configurable epoc FIRSTYEAR for converting the F1.. counter to datetime format but struct_to_counter() has a hard coded offset. It is set to the year 2000 in the example
result -= 730485UL;
Can be changed to UNIX time
result -= 719528UL;
This really needs converting into a macro if it is to be compile time configurable.
I don't think any other time.h functionality should really be required.
saraben
barthess
Post by barthess »
rtcGetTimeFat() for hardware calendar moved inside driver and tested on F4x board (rev 4701).
saraben,
thanks for link, I will look close this evening.
barthess
Post by barthess »
Giovanni,
is licensing scheme allow to use this code in chibios?
http://code.google.com/p/sistemasembebi ... /rtc.c?r=9
