STM32 Ethernet Demo
botdream
Re: STM32 Ethernet Demo
Post by botdream »
Thanks guys, that would really rock!
Regards,
Nelson.
Hi everybody,
I just fixed two bugs that could affect the MAC functionality, one regarding the MAC clock divider (it worked out of spec for clocks above 100MHz) and the other regarding the MCO1 output, this one could affect PHY clocked through that output.
Trunk updated, thanks to ninesunsz for finding them.
- FIX: Fixed wrong MAC divider setting in STM32 MAC driver (bug 3531290)
  (backported to 2.4.2).
- FIX: Fixed wrong MCO1 divider in STM32F2/F4 HAL (bug 3531289)(backported
  to 2.4.2).
kgysmits
Post by kgysmits »
kgysmits wrote:I have attached a part of the STM32F4 with KSZ8031 design. The prototypes work with the FreeRTOS lwIP demo, no further tests were done.
To solder the center pad, you could design your board with a nice big via underneath the chip so you can solder it by hand. 50% solder coverage is plenty for a good connection. The pads on the edges of the board are easy to solder, as they are also accessible from the side somewhat. make sure your proto footprint pads stick out from underneath the chip at least 2mm.
Don't expect my testing results any time soon, got a few exams coming up and a school project to catch up with first.
Slightly offtopic: the design files of the board referred to in my quoted post above are now available at https://github.com/HU-ARMBoard/HU-ARMBoardV5.
Any suggestions for a BSD-style open hardware license?
bxm
Post by bxm »
May be I've missed something, but why 2.4.x branch doesn't have lwip_bindings in the os/various? It doesn't exist either in release files, neither in the svn repo.
Thanks for finding, I'll open a ticket about this, in the meanwhile you may use the lwip_bindings from the repository version.
bxm
Post by bxm »
Giovanni wrote:meanwhile you may use the lwip_bindings from the repository version.
That's what I'm doing now. And while we're at it, the small patch suggested to make lwip location configurable:
Index: lwip.mk
--- lwip.mk   (revision 4259)
+++ lwip.mk   (working copy)
@@ -1,5 +1,5 @@
 # List of the required lwIP files.
-LWIP =    ${CHIBIOS}/ext/lwip-1.4.0
+LWIP? =    ${CHIBIOS}/ext/lwip-1.4.0
 LWBINDSRC = \
         $(CHIBIOS)/os/various/lwip_bindings/lwipthread.c \
and minor nit for readme:
Index: readme.txt
--- readme.txt   (revision 4259)
+++ readme.txt   (working copy)
@@ -1,6 +1,6 @@
 This directory contains the ChibiOS/RT "official" bindings with the lwIP
 TCP/IP stack: http://savannah.nongnu.org/projects/lwip
-In order to use FatFS within ChibiOS/RT project, unzip FatFS under
+In order to use lwIP within ChibiOS/RT project, unzip lwIP under
 ./ext/lwip-1.4.0 then include $(CHIBIOS)/os/various/lwip_bindings/lwip.mk
 in your makefile.
mabl
Post by mabl »
I'm currently trying to get Rev. B of the STM32P107 to work. I've exchanged the PHY ID and it is successfully detected. and mii_read can read all registers. But once I'm in mac_lld_start, mii_read only returns 65535 for every register. I'm totally out of ideas now why this is - anybody got an idea?
Is some pin reprogrammed before you get in macStart() ?
mabl
Post by mabl »
Giovanni wrote:Is some pin reprogrammed before you get in macStart() ?
good catch. I ignored that first, since I did no explicit reprogramming myself BUT I forgot to remap the USART2 - so the alternate functions conflicted. *argh*
Thanks again for keeping me on track!
mabl
Post by mabl »
just a small correction for the LWIP layer. When you create mutex/semaphores etc. you have to increase the internal LWIP statistics with
    SYS_STATS_INC_USED(sem);
//NOT
    SYS_STATS_INC(sem.used);
Since SYS_STATS_INC_USED will also set the "watermark", i.e. the maximum usage that ever happened.
