andypiper
Posts: 65 Joined: Sat Oct 24, 2020 5:21 pm
Has thanked: 5 times
Been thanked: 4 times
Post
by andypiper » Fri Jan 22, 2021 9:58 am
Giovanni wrote: Hi,
No need to struggle too much, in mcuconf.h there is this:
/* * Memory attributes settings. */ #define STM32_NOCACHE_MPU_REGION MPU_REGION_6 #define STM32_NOCACHE_SRAM1_SRAM2 FALSE #define STM32_NOCACHE_SRAM3 TRUEThe related code is in hal_lld.c, you can use that as example.
Ah great thanks. We are on 19.1.x at the moment - is this a later feature?
Posts: 14891 Joined: Wed May 27, 2009 8:48 am
Has thanked: 1202 times
Been thanked: 996 times
Post
by Giovanni » Fri Jan 22, 2021 10:02 am
Yes, H7 support has been enhanced, you may look at current code and do this at application level before calling halInit(). Giovanni
andypiper
Post
by andypiper » Fri Jan 22, 2021 10:18 am
Giovanni wrote: Yes, H7 support has been enhanced, you may look at current code and do this at application level before calling halInit(). Giovanni
Thanks, which LLD? I was looking for MPU but that doesn't exist?
Post
by Giovanni » Fri Jan 22, 2021 10:24 am
It is not an LLD, it is under /os/hal/ports/common/ARMCMx. Giovanni
andypiper
Post
by andypiper » Fri Jan 22, 2021 10:27 am
Giovanni wrote: It is not an LLD, it is under /os/hal/ports/common/ARMCMx. Giovanni
Thanks!
andypiper
Post
by andypiper » Fri Jan 22, 2021 10:42 am
andypiper wrote: Giovanni wrote: Hi,
It looks like I can just set STM32_NOCACHE_SRAM1_SRAM2 and use memory from 0x30000000 for now?
Post
by Giovanni » Fri Jan 22, 2021 11:39 am
You can make any combination of the two settings, you could also add extra regions if you want. Giovanni
andypiper
Post
by andypiper » Fri Jan 22, 2021 12:34 pm
Giovanni wrote: You can make any combination of the two settings, you could also add extra regions if you want. Giovanni
Thanks Giovanni. So I think this will clear up any DMA problems I am currently having (I notice on F7 we are using DTCM memory so that may explain some of the differences I am seeing between F7 and H7).
Is the gcc volatile keyword observed correctly for data located in cachable memory?
Post
by Giovanni » Fri Jan 22, 2021 1:41 pm
On F7 DTCM is accessible by DMAs, this is not the case on the H7. F7 is generally much easier to use.
No, the compiler is not cache-aware.
andypiper
Post
by andypiper » Fri Jan 22, 2021 2:57 pm
Giovanni wrote: On F7 DTCM is accessible by DMAs, this is not the case on the H7. F7 is generally much easier to use.
Urg, so I guess the next question is do the ChibiOS mutexs provide a memory barrier (I guess not since you need help frome the compiler) and does it matter on a single core H743? If I have multiple threads interacting through SRAM what do I need to do to ensure I don't get dirty reads and the like.
