If I override the switch to SDC_CLK_50MHz in sdcConnect() then writes to the card are working.
But what could be different between reads and writes at the higher clock rate
if ((SDIO->STA & SDIO_STA_DATAEND) == 0)Code: Select all
memset(buf, 0xAA, MMCSD_BLOCK_SIZE * 2);
chprintf(chp, "Writing...");
if(sdcWrite(&SDCD1, startblk, buf, 2)) {
chprintf(chp, "failed\r\n");
goto exittest;
chprintf(chp, "OK\r\n");
memset(buf, 0x55, MMCSD_BLOCK_SIZE * 2);
chprintf(chp, "Reading...");
if (blkRead(&SDCD1, startblk, buf, 1)) {
goto exittest;
for (i = 0; i < MMCSD_BLOCK_SIZE; i++)
buf[i] = i;
goto exittest;
memset(buf, 0, MMCSD_BLOCK_SIZE * 2);
goto exittest;
ch> sdc all
Connecting... OK
Card Info
CSD : 400E0032 5B590000 1D6F7F80 0A4000A0
CID : 27504853 44303447 30001800 4D00D1A8
Mode :
Capacity : 3768MB
Single block aligned read performance: 2386 blocks/S, 1221632 bytes/S
16 sequential blocks aligned read performance: 17184 blocks/S, 8798208 bytes/S
Single block unaligned read performance: 2361 blocks/S, 1208832 bytes/S
16 sequential blocks unaligned read performance: 2640 blocks/S, 1351680 bytes/S
ch> sdc all
Connecting... OK
Card Info
Mode :
Capacity : 3768MB
Single block aligned read performance: 1967 blocks/S, 1007104 bytes/S
16 sequential blocks aligned read performance: 15024 blocks/S, 7692288 bytes/S
Single block unaligned read performance: 1950 blocks/S, 998400 bytes/S
16 sequential blocks unaligned read performance: 2144 blocks/S, 1097728 bytes/S
sdcErase() test write failedCode: Select all
ch> sdc all
Connecting... OK
Card Info
CID : 02544D53 41303447 1338A23F A800E156
Mode :
Capacity : 3768MB
Single block aligned read performance: 1571 blocks/S, 804352 bytes/S
16 sequential blocks aligned read performance: 11712 blocks/S, 5996544 bytes/S
Single block unaligned read performance: 1562 blocks/S, 799744 bytes/S
16 sequential blocks unaligned read performance: 1680 blocks/S, 860160 bytes/S
ch> sdc all
Connecting... OK
Card Info
Mode :
Capacity : 3768MB
16 sequential blocks unaligned read performance: 1680 blocks/S, 860160 bytes/SCode: Select all
Address 0 - 3 4 - 7 8 - B C - F
200014E0 08090A0B 0CD0EF10
200014F0 11121314 15161718 191A1B1C D1EF2021
20001500 22232425 26272829 2A2B2CD2 EF303132
20001510 33343536 3738393A 3B3C3DE3 F0414243
20001520 44454647 48494A4B 4C4D4E4F 50515253
20001530 54555657 58595A5B 5C5D5E5F 60616263
20001540 64656667 68696A6B 6C6D6E6F 70717273
20001550 74757677 78797A7B 7C7D7E7F 80818283
20001560 84858687 88898A8B 8C8D8E8F 90919293
void sdc_lld_set_data_clk(SDCDriver *sdcp, sdcbusclk_t clk) {
(void)sdcp;
if (SDC_CLK_50MHz == clk) {
SDIO->CLKCR = (SDIO->CLKCR & 0xFFFFFF00) | STM32_SDIO_DIV_HS
/*| SDIO_CLKCR_BYPASS*/;
else
SDIO->CLKCR = (SDIO->CLKCR & 0xFFFFFF00) | STM32_SDIO_DIV_HS;
