Serial Initialization in Dem Crashes on Nucleo STM32F030R8T6
Re: Serial Initialization in Dem Crashes on Nucleo STM32F030
USART 2 is wired to the ST-Link, you see it as an USB serial port.
carldong
Post by carldong »
Yes, it is connected as /dev/ttyACM0, but I don't get anything there. BTW, I just noticed that my title is wrong...
This strange, because USART2 is how I get the test report, is it possible there is a problem with the virtual com on Linux? could you make a test on a windows machine?
carldong
Post by carldong »
I did not set up anything on a Windows machine so I can't test for now... However, I tried standalone code before, both on this board and on a STM32F130RB Nucleo board, and those don't work either(on Linux).
Could you try another flavor of Linux from a CD? you just need to see if there is output.
carldong
Post by carldong »
I will try that.
avshap
Re: Serial Initialization in Dem Crashes on Nucleo STM32F030R8T6
Post by avshap »
Sorry for thread necromancy, but I have same problem (ChibiOS 16.1.5): STM32F0 demo hangs at USART initialization (gdb freeze at
u->BRR = (uint32_t)(sdp->clock / config->speed);
) when compiled by Calculate Linux (Gentoo derivative) cross-compiler but works like a charm when compiled by Debian Unstable/Ubuntu 16.04 toolchain.
P.S. Copy of my arm-none-eabi-gcc -v output:
COLLECT_GCC=/usr/x86_64-pc-linux-gnu/arm-none-eabi/gcc-bin/4.9.4/arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/arm-none-eabi/4.9.4/lto-wrapper
Target: arm-none-eabi
Configured with: /var/calculate/tmp/portage/cross-arm-none-eabi/gcc-4.9.4/work/gcc-4.9.4/configure --host=x86_64-pc-linux-gnu --target=arm-none-eabi --build=x86_64-pc-linux-gnu --prefix=/usr --bindir=/usr/x86_64-pc-linux-gnu/arm-none-eabi/gcc-bin/4.9.4 --includedir=/usr/lib/gcc/arm-none-eabi/4.9.4/include --datadir=/usr/share/gcc-data/arm-none-eabi/4.9.4 --mandir=/usr/share/gcc-data/arm-none-eabi/4.9.4/man --infodir=/usr/share/gcc-data/arm-none-eabi/4.9.4/info --with-gxx-include-dir=/usr/lib/gcc/arm-none-eabi/4.9.4/include/g++-v4 --with-python-dir=/share/gcc-data/arm-none-eabi/4.9.4/python --enable-languages=c --enable-obsolete --enable-secureplt --disable-werror --with-system-zlib --enable-nls --without-included-gettext --enable-checking=release --with-bugurl=https://bugs.gentoo.org/ --with-pkgversion='Gentoo 4.9.4 p1.0, pie-0.6.4' --enable-poison-system-directories --disable-shared --disable-libatomic --disable-threads --without-headers --disable-bootstrap --with-newlib --enable-multilib --disable-altivec --disable-fixed-point --disable-libgcj --disable-libgomp --disable-libmudflap --disable-libssp --disable-libcilkrts --disable-vtable-verify --disable-libvtv --disable-libquadmath --enable-lto --without-cloog --disable-libsanitizer
Thread model: single
gcc version 4.9.4 (Gentoo 4.9.4 p1.0, pie-0.6.4)
P.P.S. Debug listings (*.map, and *.dmp) for NUCLEO-F030R8 demo (compiled with disabled optimization) are attached.
xubuntu_dbg_list.zip
Debug listings for working firmware.
(191.28 KiB) Downloaded 359 times
gentoo_dbg_list.zip
Debug listings for faulty firmware.
(197.19 KiB) Downloaded 345 times
It already happened that compilers included in distributions fail, those compilers are not really tested, just compiled from source IMHO.
I suggest you use this one: https://launchpad.net/gcc-arm-embedded
You can install it in any Linux flavor and it is known to work perfectly.
