SDIO port to STM32F4x
Re: SDIO port to STM32F4x
Very well, is the driver functional for F1 family too?
barthess
Post by barthess »
I can not test it on F1x. But driver use the same concepts as previous realization. Platform specific code is DMA related and hidden in #if#endif blocks.
One question about naming conventions STM32_SDIO_XXXXX or STM32_SDC_XXXXX ?
barthess
Post by barthess »
 * @brief   Driver configuration structure.
 * @note    It could be empty on some architectures.
typedef struct {
  uint32_t dummy;
} SDCConfig;
may be delete "uint32_t dummy;" at all?
The driver is "SDC" so it should be named accordingly, empty structures are not standard C and some compilers warns about that.
barthess
Post by barthess »
1) What about SDC_BUSY_HOOK() and SDC_IDLE_HOOK() to easy realize "hdd led indicator"?
2) Now we can have a deal with RTC. I propose to add it support after finalizing of RTC code on F4/F2 platforms.
Better do not add macros in a LLD for things that can be done outside the driver, you can make a led blink without those, I can think several ways to do that. Adding options increases complexity and reduces maintainability.
barthess
Post by barthess »
I create new branch from trunk. Code compiles without problems. I plans to concentrate efforts on test suit.
Badger
Post by Badger »
Hi barthess,
Do you use pullups for SDIO on the F4? It's been a while since I looked into it, but as far as I can remember the F1 datasheet showed the pullups where as I couldn't find a similar diagram for the F4. I guess an extended request would be: can you provide details of how you've connected the SD card to the STM32F4 in SDIO mode?
Thanks!
barthess
Post by barthess »
I connect it like in STM32-LCD board (connection identical for F1 and F4) from Olimex but without pullup resistors. You can found datasheet with diagrams on Olimex page. I do not observe any problems without external pullups but strongly recommend to insert them to be safe. In my case I just forgot about them when developing board.
Badger
Post by Badger »
Thanks for the hint, I'll probably do my testing without them to see if I have success, and will try and find a resistor array for when I design a PCB! I'll order an SD card breakout so I can help with testing, I have lots of SD cards lying around :D
