Page 3 of 4
Re: getting Hard Fault when using fast interrupts
Posted: Sun Apr 19, 2015 7:04 pm
This is strange and I don't like what it could mean, it seems that fast IRQ interacts badly with the rescheduling code.
I will try to reproduce the problem on my side.
Posted: Sun Apr 19, 2015 7:25 pm
I tried on an STM32F3 and failed to reproduce the error using both GCC and Keil.
This is the main() I used:
ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "test.h"
* Blinker thread #1.
(void)arg;
while (true) {
palSetPad(GPIOE, GPIOE_LED3_RED);
chThdSleepMilliseconds(125);
palClearPad(GPIOE, GPIOE_LED3_RED);
palSetPad(GPIOE, GPIOE_LED7_GREEN);
palClearPad(GPIOE, GPIOE_LED7_GREEN);
palSetPad(GPIOE, GPIOE_LED10_RED);
palClearPad(GPIOE, GPIOE_LED10_RED);
palSetPad(GPIOE, GPIOE_LED6_GREEN);
palClearPad(GPIOE, GPIOE_LED6_GREEN);
* Blinker thread #2.
static THD_WORKING_AREA(waThread2, 128);
static THD_FUNCTION(Thread2, arg) {
(void)arg;
while (true) {
palSetPad(GPIOE, GPIOE_LED5_ORANGE);
palClearPad(GPIOE, GPIOE_LED5_ORANGE);
palSetPad(GPIOE, GPIOE_LED9_BLUE);
palClearPad(GPIOE, GPIOE_LED9_BLUE);
palSetPad(GPIOE, GPIOE_LED8_ORANGE);
palClearPad(GPIOE, GPIOE_LED8_ORANGE);
palSetPad(GPIOE, GPIOE_LED4_BLUE);
palClearPad(GPIOE, GPIOE_LED4_BLUE);
CH_FAST_IRQ_HANDLER(VectorA4)
uint8_t i;
GPIOD->BSRR.H.set=1<<15;
for(i=0;i<10;i++);
TIM1->SR=0;
GPIOD->BSRR.H.clear=1<<15;
(void) __get_FPSCR();
* Application entry point.
int main(void) {
* System initializations.
* RTOS is active.
* Activates the serial driver 1 using the driver default configuration.
* PA9(TX) and PA10(RX) are routed to USART1.
sdStart(&SD1, NULL);
palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7));
palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7));
RCC->APB2ENR|=RCC_APB2ENR_TIM1EN;
* Creates the example threads.
chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO+1, Thread2, NULL);
TIM1->ARR=2000;
TIM1->PSC=0;
TIM1->DIER=1;
NVIC_SetPriority(TIM1_UP_TIM16_IRQn, 1);
NVIC_ClearPendingIRQ(TIM1_UP_TIM16_IRQn);
NVIC_EnableIRQ(TIM1_UP_TIM16_IRQn);
TIM1->CR1=1;
* sleeping in a loop and check the button state, when the button is
* pressed the test procedure is launched.
while (true) {
if (palReadPad(GPIOA, GPIOA_BUTTON))
TestThread(&SD1);
chThdSleepMilliseconds(500);
I also added an FPU operation in the timer ISR in order to trigger a state save, but it also worked. I used ChibiOS 3.0, if nothing changes tomorrow I will try on 2.6.8 but the port code is the same.
In the meanwhile, could you try to enable assertions, checks and "state checker" in chconf.h?
Posted: Sun Apr 19, 2015 8:21 pm
by Coreglider
I already enabled them and posted a screenshot with a result of debug check.
Ok, I'll try your code tomorrow on f4.
Posted: Sun Apr 19, 2015 8:27 pm
The messages was only partially visible: "S". Next time could you get the whole string pointed by panic_dbg_msg?
Posted: Sun Apr 19, 2015 8:31 pm
by Coreglider
"SV#4" it can be seen on screenshot
Posted: Sun Apr 19, 2015 8:39 pm
SV#4 can happen in two cases:
* - SV#4, misplaced @p chSysLock().
* - Called from an ISR.
* - Called from a critical zone.
If chSysLock() is called from an ISR or callback or if it is called from a critical zone: two consecutive chSysLock(). Something I don't see in your code.
Posted: Mon Apr 20, 2015 1:08 pm
by Coreglider
You code with some modifications to run it under 2.6.8 get the same result - stuck in the context switching or in idle thread. But I didn't get chDbgPainic event, despite all checks are enabled. When I edited thread code (just added more led switching commands), I get chDbgPainic with "stack overflow" message.
Posted: Mon Apr 20, 2015 4:42 pm
Please try compiling with -O2, stack overflows should go.
I will post more details later.
Posted: Mon Apr 20, 2015 6:01 pm
You may try to define:
#define PORT_INT_REQUIRED_STACK 128
in chconf.h, this will increase the stack area of all threads, including the idle one. The default is 32 and maybe it is not sufficient under your conditions.
Posted: Tue Apr 21, 2015 1:38 pm
by Coreglider
Do you found any interactions between fast interrupts and context switching code (with FPU enabled)?
