Is Aduino Uno is supported? Topic is solved
Moderator: tfAteba
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Re: Is Aduino Uno is supported?
Post by tfAteba »
@Igor,
Well ;) I finally understand what you try to explain to me. So I need to invest to buy some external debugger ;).
But for now, print and gpoi are my best tools;), I'm going to deal with. Thanks you Igor
Theo
tfAteba
Post by tfAteba »
Hello Igor, Fabio,
I finaly have the time this days, and I have tested hall the GPIO of the Arduino Uno. It work fine.
Now, I have to move on, by testing or writing a peace of code to test other module for the board(arduino uno with atmega328p).
I need UART, I2C, PWM, INT for my self-balancing robot project.
If you have any advices, you are welcome.
Thanks, Theo.
utzig
Been thanked: 20 times
Post by utzig »
UART, I2C and PWM are already supported. Since UART and I2C are much simpler and also very restricted on what PINs you must use, start from there. PWM works but has limitations of which the main one is that you cannot share timers. If you are using TIM0 for the ticker you'll only have TIM1 or TIM2 (I don't remember how many are on the 328p). For INT, an ext driver was contributed by Igor and is available on his Github. As soon as I get some free time I'll try to incorporate it, which could happen before you need it, maybe. You can also do the manual programming of INTs which is not that hard.
If you change/fix issues in drivers, we'll be happy to get your feedback/patches.
Kind regards,
Fabio Utzig
