I prefer to keep chprintf minimal, it is not meant to be a full implementation, it has to be as small as possible. It is not like you can't print 8/16 bits values using the normal formatters.
[INFO] lwIP version 2.0 Topic is solved
Re: [INFO] lwIP version 2.0
Dear Marco,
Yes, this also means, we can make a fully functional ChibiOS - LWIP 2.0 integration without either GPRS modem or even USB to TTL adapter.
Btw, this is already done on David Albert's article long time ago. And I did lot of LWIP test (Unix port) only with PPPD before moving to real GPRS modem.
[2] David Albert wonderful article about ChibiOS, PPP new and Linux PPPD
I did put other two very useful references on the readme file: https://bitbucket.org/quanghgx/rt-stm32 ... y-lwip-ppp
Thank you Marco.
The nice thing about the pppos netif would be that you can choose between the SerialDriver or Serial over USB driver as interface.
Thank you Marco.
Dear Marco,
I've just updated the "minimal change" LWIP 2.0 binding version:
STM32F4 Discovery default usb port (OTG-FS) only has 4 end-points, so cannot have dual USB Serials. The logging remain using SD2. Btw, people now can test LWIP 2.0 PPPoS integration without anything other than a STM32F4 Discovery board itself.
I did successful running a fully integrated LWIP 2.0 and MQTT (paho C client) with ChibiOS on a STM32F103 with 48KB of RAM. It has been running smoothly for almost a week now.
Todo: make lwip.mk like original ChibiOS LWIP binding, handling PPP reconnection and link status on STM32F4 Discovery demo.
Here is the link again.
Thank you Marco.
- Using USB Serial instead of Serial.
Using actual ChibiOS mutex as LWIP_TCPIP_CORE_LOCK is default in LWIP 2.0 (recommended by LWIP document)
Thank you Marco.
Hi quanghgx,
Thanks for the new update!
Yesterday i also got pppos working (using SerialDriver) with pppd on ubuntu so my idea works. It is very easy to start a network interface like ethernet or pppos or even two pppos interfaces. They also run simultaneously. I will try to put my work so far on Github tonight so you can also review it.
Marco
Marco
I put my work so far for the lwip bindings here on Github: https://github.com/marcoveeneman/ChibiO ... wip_update
I only tested it on a modified demo for the Tiva TM4C1294 Launchpad but it should be easy to adapt for other boards as long as they support the MAC and SD drivers. In this demo there are two network interfaces; Ethernet and PPPoS.
SD1 is used for lwip debug output and SD4 is used for the pppos connection.
Here is the modified main.c file from the contrib repository on github.
Note that this is still a very early draft version so please comment
Marco
Copyright (C) 2014..2016 Marco Veeneman
#include "ch.h"
#include "lwipthread.h"
#include "lwip_ethernetif.h"
#include "lwip_ppposif.h"
#include "web/web.h"
#define LWIP_ETHADDR_0 0xC2
#define LWIP_ETHADDR_1 0xAF
#define LWIP_ETHADDR_2 0x51
#define LWIP_ETHADDR_3 0x03
#define LWIP_ETHADDR_4 0xCF
#define LWIP_ETHADDR_5 0x46
#define LWIP_IFNAME0 'm'
#define LWIP_IFNAME1 's'
static uint8_t mac_address[ETHARP_HWADDR_LEN] = { LWIP_ETHADDR_0,
LWIP_ETHADDR_1,
LWIP_ETHADDR_2,
LWIP_ETHADDR_3,
LWIP_ETHADDR_4,
LWIP_ETHADDR_5 };
static const MACConfig mac_config = {
mac_address
static const LwIPEthernetIFConfig ethernet_config = {
ÐD1,
&mac_config,
{ LWIP_IFNAME0, LWIP_IFNAME1 },
IPADDR4_INIT(PP_HTONL(0xC0A8010AUL)), /* 192.168.1.10 */
IPADDR4_INIT(PP_HTONL(0xC0A80101UL)), /* 192.168.1.1 */
IPADDR4_INIT(PP_HTONL(0xFFFFFF00UL)) /* 255.255.255.0 */
static LwIPEthernetIFDriver ethernet;
static const LwIPPPPoSIFConfig pppos_config = {
&SD4,
NULL,
"aa"
static LwIPPPPoSIFDriver pppos;
#define LINE_UART3_RX PAL_LINE(GPIOA, 4U)
#define LINE_UART3_TX PAL_LINE(GPIOA, 5U)
* Application entry point.
int main(void)
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
* - lwIP subsystem initialization.
/* Configure RX and TX pins for UART0.*/
palSetLineMode(LINE_UART0_RX, PAL_MODE_INPUT | PAL_MODE_ALTERNATE(1));
palSetLineMode(LINE_UART0_TX, PAL_MODE_INPUT | PAL_MODE_ALTERNATE(1));
/* Configure RX and TX pins for UART1.*/
palSetLineMode(LINE_UART3_RX, PAL_MODE_INPUT | PAL_MODE_ALTERNATE(1));
palSetLineMode(LINE_UART3_TX, PAL_MODE_INPUT | PAL_MODE_ALTERNATE(1));
* Start the serial driver with the default configuration.
* Used for debug output of LwIP.
sdStart(&SD1, NULL);
/* Initialize LwIP */
lwipInit();
* Initialize and start the LwIP ethernet interface.
lwipEthernetIFObjectInit(ðernet);
lwipEthernetIFStart(ðernet, ðernet_config);
* Initialize and start the LwIP PPPoS interface.
lwipPPPoSIFObjectInit(&pppos);
lwipPPPoSIFStart(&pppos, &pppos_config);
* Creates the HTTP thread (it changes priority internally).
chThdCreateStatic(wa_http_server, sizeof(wa_http_server), NORMALPRIO + 1,
http_server, NULL);
while (1) {
osalThreadSleepMilliseconds(500);
return 0;
Marco
I see you are encapsulating the application-facing functions in a ChibiOS-like APIs, good idea, will help users feel at home
Giovanni wrote:I see you are encapsulating the application-facing functions in a ChibiOS-like APIs, good idea, will help users feel at home
Correct
This also makes it very easy to start and stop a network interface on the fly. I will try to improve the code a bit and maybe add a PPPoE network interface driver.
Marco
