Page 3 of 9
Re: [PATCH] AVR EXT
Posted: Thu Nov 10, 2016 11:27 am
by igor
tfAteba wrote:I supposed that you made your test with atmega328p mcu only?
Yes, that is correct.
tfAteba wrote:If so, I will also made test with mega2560 to see if every things is fine.
thanks
tfAteba wrote:Also for test, did you use the same test program under testhal/AVR/EXT withoug any modifications? If y made your own test application could you also add it.
No, I used my application, which uses 4 input lines as interrupt sources.
I also used my board and makefile, still from the same application.
Now that you have proper board fiels for MiniPro, I'm planning to move to them, so I'll confirm that everything works fine.
Unfortunately ATM I do not have too much time available for this hobby.
Re: [PATCH] AVR EXT
Posted: Thu Nov 10, 2016 6:06 pm
by tfAteba
Ok, thanks for your answer.
I hope I will have the time this week to look after your patch.
So I will also add a small demo to test this hal feature.
Don't worry if you don't have the time now to make some tests. However, it will also be nice if you can test with the MiniPro board, bacause I don't have one :) .
Thank you.
Re: [PATCH] AVR EXT
Posted: Mon Nov 28, 2016 9:26 am
by tfAteba
Hi Igor,
Please can you make a small example on how to use PCINTs, it will be very helpful for me. :D
You even work on it so I hope it will not take you so much to do it?
Thanks for your understanding.
Re: [PATCH] AVR EXT
Posted: Thu Mar 23, 2017 11:51 am
by Marco
I'd like to see support for PCINT interrupts in trunk. Is there still something missing which prevents this?
Marco
Re: [PATCH] AVR EXT
Posted: Thu Mar 23, 2017 1:42 pm
by utzig
I remember taking a quick look at the patches. The things that I didn't like were the changes to the license headers, which IMO should only be done by invitation, also there where so many changes that it would maybe be better to just send the files (not a patch)... but it looked OK to me and I don't remember seeing anything wrong.
Marco/Theo, if you reviewed it and didn't see anything wrong I would suggest applied it.
Cheers,
Fabio Utzig
Re: [PATCH] AVR EXT
Posted: Thu Mar 23, 2017 2:35 pm
by Marco
Hi Fabio,
I tried to apply the patch to trunk but it didn't work for me, I applied it manually. Let me try the driver on an ATMega162 and i'll report back soon.
Marco
Re: [PATCH] AVR EXT
Posted: Thu Mar 23, 2017 2:42 pm
by tfAteba
Hi All,
I'm sorry, I did have the time to look at the patch.
I will also try to have a look at it and also give a feedback.
If it looked good for me I will apply as suggest by Utzig.
Re: [PATCH] AVR EXT
Posted: Mon Mar 27, 2017 2:32 pm
by Marco
I found some issues in the driver. I will try to create a new patch later today.
Marco
Re: [PATCH] AVR EXT
Posted: Mon Mar 27, 2017 4:44 pm
by Marco
Marco wrote:Hi,
Marco
It will be tomorrow.
Re: [PATCH] AVR EXT
Posted: Mon Mar 27, 2017 8:14 pm
by tfAteba
Hi Marco,
Thanks you for your help.
Which issues did you found?
I will then wait to test with you patch.
Like you, I also had some difficulties to apply Igor's patch. But I did't spend so much time to resolve the problem.
