Page 3 of 3
Re: HardFault and debug with messagebox
Posted: Fri Feb 24, 2017 2:29 pm
by omcdr
GCC 4.9 2015q3 from ChibiStudio
Posted: Fri Feb 24, 2017 3:21 pm
I am out of ideas, you should try to isolate parts of the program and try to isolate what triggers the problem, it is not necessarily around where it stops.
Posted: Sun Mar 12, 2017 3:31 pm
by omcdr
I have compiled my project under IAR and code is working correctly, without hardfault, I have tested with various sprintf, xprintf functions.
Is this a bug in gcc ? I don't know how to find it.
In IAR I have based on linker script ch.icf from IRQ_STORM example, but I got warning message in debug:
The stack pointer for stack 'CSTACK' (currently 0x20000400) is outside the stack range (0x20007C00 to 0x20008000)
How to set correct CSTACK value ?
Full script is here
define symbol __ICFEDIT_intvec_start__ = 0x08000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0x08000000;
define symbol __ICFEDIT_region_ROM_end__   = 0x0801FFFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x20000000;
define symbol __ICFEDIT_region_RAM_end__   = 0x20007FFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x400;
define symbol __ICFEDIT_size_heap__   = 0x400;
/**** End of ICF editor section. ###ICF###*/
/* Size of the IRQ Stack (Main Stack).*/
define symbol __ICFEDIT_size_irqstack__   = 0x400;
define memory mem with size = 4G;
define region ROM_region   = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__];
define region RAM_region   = mem:[from __ICFEDIT_region_RAM_start__   to __ICFEDIT_region_RAM_end__];
define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   {section CSTACK};
define block IRQSTACK  with alignment = 8, size = __ICFEDIT_size_irqstack__ {};
define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     {};
define block SYSHEAP   with alignment = 8                                   {section SYSHEAP};
define block DATABSS with alignment = 8 {readwrite, zeroinit};
initialize by copy { readwrite };
do not initialize  { section .noinit };
keep { section .intvec };
place at address mem:__ICFEDIT_intvec_start__ {section .intvec};
place in ROM_region                           {readonly};
place at start of RAM_region                  {block IRQSTACK};
place in RAM_region                           {block DATABSS, block HEAP};
place in RAM_region                           {block SYSHEAP};
place at end of RAM_region                    {block CSTACK};
Posted: Sun Mar 12, 2017 4:59 pm
That message is normal, the various threads can have their stacks outside that area and the debugger issues a warning.
Posted: Sun Mar 12, 2017 6:05 pm
by omcdr
Ok, thank you for debugging this issue.
