ChibiOS/testhal/STM32F4xx/USB_CDC
Re: ChibiOS/testhal/STM32F4xx/USB_CDC
I think it is fixed now, queues are now reinitialized after each reset. The driver also received optimizations to the data copy routines, it should be much faster now.
Hello Giovanni,
I found 2 problems with the driver.
1. On OSX and a vmware virtual machine the enumeration fails. The address needs to be reset to 0 in usb_lld_reset().
( OTG->DCFG = (OTG->DCFG & ~DCFG_DAD_MASK) | DCFG_DAD(0); )
2. When I use termite as terminal program (In windows XP) the commands are send in 1 buffer. Only the first character is recognized.
When I use a normal terminal program it works perfectly.
Best regards,
Erik
Best regards,
Erik
Fixed the device address initialization, I thought it was automatic on reset...
I am looking into the other issue, it looks like there are problems with large incoming packets, probably a problem in the function that fills the input queue.
the usb driver, is it ready also for other applications?
For example: device usb hid (mouse or keyboard, or host usb hid attach a mouse or keyboard. device/host msd.
Thank you
EDIT
wrong word device usb not driver usb
Thank you
EDIT
I'm testing this out on Ubuntu.
Upon inserting, the device enumerates and lsusb gives this output:
ubuntu sets the device as /dev/ttyACM0
The default udev rules seem to prohibit accessing it as a normal user. but as root it worked:
the shell seemed to work.
Now to try it on my own boards!
edit: tried it and it works! http://www.youtube.com/watch?v=UareDFcnZTY&feature=plcp
Bus 001 Device 016: ID 0483:5740 SGS Thomson Microelectronics
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0483 SGS Thomson Microelectronics
idProduct 0x5740
bcdDevice 2.00
iManufacturer 1 STMicroelectronics
iProduct 2 ChibiOS/RT Virtual COM Port
iSerial 3 250
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 67
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x02
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 255
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0001
Self Powered
[ 2982.024285] usb 1-1.5.1.4: new full-speed USB device number 17 using ehci_hcd
[ 2982.118113] cdc_acm 1-1.5.1.4:1.0: This device cannot do calls on its own. It is not a modem.
[ 2982.118139] cdc_acm 1-1.5.1.4:1.0: ttyACM0: USB ACM deviceThe default udev rules seem to prohibit accessing it as a normal user. but as root it worked:
sudo screen /dev/ttyACM0the shell seemed to work.
On my linux I wrote a simple udev rule.Badger wrote:The default udev rules seem to prohibit accessing it as a normal user. but as root it worked:Code: Select all
file /etc/udev/rules.d/99-usbdevice.rules
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", MODE="0666"So all usb devices are writable by all users. Maybe it isn't very good for security but works.
You can restrict also to a single device:
SUBSYSTEM=="usb_device", ATTR{idVendor}=="0483", ATTR{idProduct}=="5740", MODE="666"or only to your username
SUBSYSTEM=="usb_device", ATTR{idVendor}=="0483", ATTR{idProduct}=="5740", OWNER="<your username>", MODE="600"or only to group
SUBSYSTEM=="usb_device", ATTR{idVendor}=="0483", ATTR{idProduct}=="5740", GROUP="<group of users>", MODE="660"- Giovanni
indigos wrote:the usb driver, is it ready also for other applications?
Yes, only support for isochronous endpoints is missing.
I don't think that I should open a new thread for this ontopic, one answer question:
I've never cared about USB before. Is there now any working example, which demonstrates how to use the USB driver of ChibiOS to do some stuff like USB HID or something else?
Maybe someone also got a linux-side example showing how to use the new /dev device?
