New Makefile Topic is solved
Moderator: tfAteba
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Re: New Makefile
Post by tfAteba »
Giovanni,
I just made the test with chibios 17.6.2.
To make the test in the same condition, I have modify the chconf.h file:
 * @brief   Core Memory Manager APIs.
 * @details If enabled then the core memory manager APIs are included
 *          in the kernel.
 * @note    The default is @p TRUE.
#define CH_CFG_USE_MEMCORE                 TRUE
 * @brief   Heap Allocator APIs.
 * @details If enabled then the memory heap allocator APIs are included
 *          in the kernel.
 * @note    Requires @p CH_CFG_USE_MEMCORE and either @p CH_CFG_USE_MUTEXES or
 *          @p CH_CFG_USE_SEMAPHORES.
 * @note    Mutexes are recommended.
#define CH_CFG_USE_HEAP                     TRUE
 * @brief   Memory Pools Allocator APIs.
 * @details If enabled then the memory pools allocator APIs are included
 *          in the kernel.
#define CH_CFG_USE_MEMPOOLS             TRUE
 * @brief   Dynamic Threads APIs.
 * @details If enabled then the dynamic threads creation APIs are included
 *          in the kernel.
 * @note    Requires @p CH_CFG_USE_WAITEXIT.
 * @note    Requires @p CH_CFG_USE_HEAP and/or @p CH_CFG_USE_MEMPOOLS.
#define CH_CFG_USE_DYNAMIC                 TRUE
The test also fail in the test sequence 11.1, but in this case, the test frezze at test case 12.1
Here is the output:
*** ChibiOS/RT Test Suite
*** Compiled:     Oct 21 2017 - 22:57:45
*** Platform:     AVR
*** Test Board:   Arduino Mega
*** Compiler:     GCC 4.9.2
*** Architecture: MegaAVR
*** Port Info:    None
--- Test Case 1.1 (Kernel Info)
--- Product:                   ChibiOS/RT
--- Stable Flag:               1
--- Version String:            4.0.2
--- Major Number:              4
--- Minor Number:              0
--- Patch Number:              2
--- Result: SUCCESS
--- Test Case 1.2 (Kernel Settings)
--- CH_CFG_ST_RESOLUTION:      16
--- CH_CFG_ST_FREQUENCY:       15624
--- CH_CFG_ST_TIMEDELTA:       2
--- CH_CFG_TIME_QUANTUM:       0
--- CH_CFG_MEMCORE_SIZE:       128
--- CH_CFG_NO_IDLE_THREAD:     0
--- CH_CFG_OPTIMIZE_SPEED:     1
--- CH_CFG_USE_TM:             0
--- CH_CFG_USE_REGISTRY:       1
--- CH_CFG_USE_WAITEXIT:       1
--- CH_CFG_USE_SEMAPHORES:     1
--- CH_CFG_USE_SEMAPHORES_PRI: 0
--- CH_CFG_USE_MUTEXES:        1
--- CH_CFG_USE_MUTEXES_RECURS: 0
--- CH_CFG_USE_CONDVARS:       1
--- CH_CFG_USE_CONDVARS_TIMEO: 1
--- CH_CFG_USE_EVENTS:         1
--- CH_CFG_USE_EVENTS_TIMEOUT: 1
--- CH_CFG_USE_MESSAGES:       1
--- CH_CFG_USE_MESSAGES_PRI:   0
--- CH_CFG_USE_MAILBOXES:      1
--- CH_CFG_USE_MEMCORE:        1
--- CH_CFG_USE_HEAP:           1
--- CH_CFG_USE_MEMPOOLS:       1
--- CH_CFG_USE_DYNAMIC:        1
--- CH_DBG_STATISTICS:         0
--- CH_DBG_SYSTEM_STATE_CHECK: 0
--- CH_DBG_ENABLE_CHECKS:      0
--- CH_DBG_ENABLE_ASSERTS:     0
--- CH_DBG_TRACE_MASK:         255
--- CH_DBG_TRACE_BUFFER_SIZE:  128
--- CH_DBG_ENABLE_STACK_CHECK: 0
--- CH_DBG_FILL_THREADS:       0
--- CH_DBG_THREADS_PROFILING:  0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Test Case 2.4 (System Tick Counter functionality)
--- Result: SUCCESS
--- Test Case 3.1 (Thread Sleep functionality)
--- Result: SUCCESS
--- Test Case 3.2 (Ready List functionality, threads priority order)
--- Result: SUCCESS
--- Test Case 3.3 (Priority change test)
--- Result: SUCCESS
--- Test Case 3.4 (Priority change test with Priority Inheritance)
--- Result: SUCCESS
--- Test Case 4.1 (Suspend and Resume functionality)
--- Result: SUCCESS
--- Test Case 5.1 (Semaphore primitives, no state change)
--- Result: SUCCESS
--- Test Case 5.2 (Semaphore enqueuing test)
--- Result: SUCCESS
--- Test Case 5.3 (Semaphore timeout test)
--- Result: SUCCESS
--- Test Case 5.4 (Testing chSemAddCounterI() functionality)
--- Result: SUCCESS
--- Test Case 5.5 (Testing chSemWaitSignal() functionality)
--- Result: SUCCESS
--- Test Case 5.6 (Testing Binary Semaphores special case)
--- Result: SUCCESS
--- Test Case 6.1 (Priority enqueuing test)
--- Result: SUCCESS
--- Test Case 6.2 (Priority return verification)
--- Result: SUCCESS
--- Test Case 6.3 (Repeated locks, non recursive scenario)
--- Result: SUCCESS
--- Test Case 6.4 (Condition Variable signal test)
--- Result: SUCCESS
--- Test Case 6.5 (Condition Variable broadcast test)
--- Result: SUCCESS
--- Test Case 6.6 (Condition Variable priority boost test)
--- Result: SUCCESS
--- Test Case 7.1 (Messages Server loop)
--- Result: SUCCESS
--- Test Case 8.1 (Events registration)
--- Result: SUCCESS
--- Test Case 8.2 (Event Flags dispatching)
--- Result: SUCCESS
--- Test Case 8.3 (Events Flags wait using chEvtWaitOne())
--- Result: SUCCESS
--- Test Case 8.4 (Events Flags wait using chEvtWaitAny())
--- Result: SUCCESS
--- Test Case 8.5 (Events Flags wait using chEvtWaitAll())
--- Result: SUCCESS
--- Test Case 8.6 (Events Flags wait timeouts)
--- Result: SUCCESS
--- Test Case 8.7 (Broadcasting using chEvtBroadcast())
--- Result: SUCCESS
--- Test Case 9.1 (Mailbox normal API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 9.2 (Mailbox I-Class API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 9.3 (Mailbox timeouts)
--- Result: SUCCESS
--- Test Case 10.1 (Loading and emptying a memory pool)
--- Result: SUCCESS
--- Test Case 10.2 (Loading and emptying a guarded memory pool without waiting)
--- Result: SUCCESS
--- Test Case 10.3 (Guarded Memory Pools timeout)
--- Result: SUCCESS
--- Test Case 11.1 (Allocation and fragmentation)
--- Result: FAILURE (#4 [] "missing free block")
--- Test Case 11.2 (Default Heap)
--- Result: SUCCESS
--- Test Case 12.1 (Threads creation from Memory Heap)
Re: New Makefile
I cannot debug on AVR, you should find details of what exactly is failing, probably it is an insufficient heap space.
tfAteba
Re: New Makefile
Post by tfAteba »
Ok Giovanni,
I can't also debug AVR, I do not have any debugger tools.
I hope I will have the opportunity to buy one this week to be able to make some debug 8-) .
So Nico, to resume, it is not the compilation option that make the test suite fails but there is some thing else.
The problem is still opened and I need some materials to investigate.
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Re: New Makefile
Post by wurstnase »
Many thanks for working on this.
I'm pretty sorry that I can't help with debugging AVRs.
tfAteba
Re: New Makefile
Post by tfAteba »
Thanks for your implication, don't worry about the debug. :lol:
Re: New Makefile
The problem has been fixed as bug #899.
Fixed in trunk, will be fixed in 17.6.3.
tfAteba
Re: New Makefile
Post by tfAteba »
Hello Giovanni,
Thanks for this good news, did you made some real tests on a board?
I will run it tonight and see if the problem is fixed if you didn't make any onboard test. I will also take a look to see what you did to solve the problem :)
tfAteba
Re: New Makefile
Post by tfAteba »
Giovanni,
When does the release version 17.6.3 is planed to be available?
I want to update some files and the global architecture of the AVR so that it look like in the trunk to be similar to STM part.
It will help me if I know the amount of time left :D
Re: New Makefile
Usually stable versions only get bug fixes, changes are for trunk until next major release.
tfAteba
Re: New Makefile
Post by tfAteba »
I got it :)
