STM32L4R5ZI-NUCLEO144 and SDC Driver: hal_sdc.h:136:10: fatal error: hal_sdc_lld.h: No such file or directory Topic is solved
Re: STM32L4R5ZI-NUCLEO144 and SDC Driver: hal_sdc.h:136:10: fatal error: hal_sdc_lld.h: No such file or directory
Not enough info, the FS is mounted in the provided demo. Any difference could be the cause of the problem, GPIO settings, clocks, type of card and possibly others.
sntnjrg
Has thanked: 18 times
Post by sntnjrg »
I'm sorry, I had a broken wire. I tried again and it failed when the f_write() function is invoked to write a data. The error occurs after validating the file object. The error is FR_DISK_ERR.
FRESULT f_write (
   FIL* fp,         /* Pointer to the file object */
   const void* buff,   /* Pointer to the data to be written */
   UINT btw,         /* Number of bytes to write */
   UINT* bw         /* Pointer to number of bytes written */
   FRESULT res;
   FATFS *fs;
   DWORD clst, sect;
   UINT wcnt, cc, csect;
   const BYTE *wbuff = (const BYTE*)buff;
   *bw = 0;   /* Clear write byte counter */
   res = validate(&fp->obj, &fs);         /* Check validity of the file object */
   if (res != FR_OK || (res = (FRESULT)fp->err) != FR_OK) LEAVE_FF(fs, res); <--- HERE,
The test tries to write a data 10000 times but fails 9984 times.
  uint32_t write_errors = 0;
  for (uint32_t i = 0; i < 10000; i++) {
    err = f_write(&FileObject, teststring, sizeof(teststring),
                  (void*)&bytes_written);
    if (err != FR_OK) {
      write_errors++;
After this part, the f_close() function is invoked. This function invokes f_sync() and then disk_write(). The function disk_write() invokes the sdcWrite() function and .... The stack is:
Thread #1 (Suspended : Step)
   sdc_lld_wait_transaction_end() at hal_sdc_lld.c:225 0x8002e08
   sdc_lld_write_aligned() at hal_sdc_lld.c:749 0x80034a6
   sdc_lld_write() at hal_sdc_lld.c:826 0x80035d2
   sdcWrite() at hal_sdc.c:846 0x8001f84
   disk_write() at fatfs_diskio.c:188 0x800a7a0
   f_sync() at ff.c:3.971 0x800cbba
   f_close() at ff.c:4.045 0x800cc8c
   fs_test() at main.c:564 0x801609c
   cmd_sdiotest() at main.c:669 0x801636e
   cmdexec() at shell.c:106 0x8009f0c
   <...more frames...>
 * @brief   Wait end of data transaction and performs finalizations.
 * @param[in] sdcp      pointer to the @p SDCDriver object
 * @param[in] n         number of blocks in transaction
 * @param[in] resp      pointer to the response buffer
 * @return              The operation status.
 * @retval HAL_SUCCESS  operation succeeded.
 * @retval HAL_FAILED   operation failed.
static bool sdc_lld_wait_transaction_end(SDCDriver *sdcp, uint32_t n,
                                         uint32_t *resp) {
  /* Note the mask is checked before going to sleep because the interrupt
     may have occurred before reaching the critical zone.*/
  osalSysLock();
  if (sdcp->sdmmc->MASK != 0)
    osalThreadSuspendS(&sdcp->thread); <-- HERE
  /* Stopping operations.*/
  sdcp->sdmmc->IDMACTRL = 0;
  sdcp->sdmmc->MASK     = 0;
  sdcp->sdmmc->DCTRL    = 0;
  if ((sdcp->sdmmc->STA & SDMMC_STA_DATAEND) == 0) {
    osalSysUnlock();
    return HAL_FAILED;
  /* Clearing status.*/
  sdcp->sdmmc->ICR      = SDMMC_ICR_ALL_FLAGS;
  osalSysUnlock();
  /* Finalize transaction.*/
  if (n > 1)
    return sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_STOP_TRANSMISSION, 0, resp);
  return HAL_SUCCESS;
The sdcp->sdmmc->MASK field is not equal to 0 and the thread is sent to sleep and never wakes up.
The configuration (clock, ...) that I am using is the one that by default comes in the RT-STM32L4R5ZI-NUCLEO144 demo on master branch.
Does the demo work for you in the current master branch of Chibios?
Thank you
What is the value of MASK when it fails?
sntnjrg
Post by sntnjrg »
This is its value: 282.
and this is the state at this moment:
sdcp   SDCDriver *   0x20000d58 <SDCD1>
   vmt   const struct SDCDriverVMT *   0x8016c4c <sdc_vmt>
   state   blkstate_t   BLK_WRITING
   cid   uint32_t [4]   0x20000d60 <SDCD1+8>
   csd   uint32_t [4]   0x20000d70 <SDCD1+24>
   capacity   uint32_t   15138816
   config   const SDCConfig *   0x8016d5c <sdc_default_cfg>
   cardmode   sdcmode_t   17
   errors   sdcflags_t   4
   rca   uint32_t   4219667744
   thread   thread_reference_t   0x0
   sdmmc   SDMMC_TypeDef *   0x50062400
      POWER   volatile uint32_t   3
      CLKCR   volatile uint32_t   20480
      ARG   volatile uint32_t   1562264
      CMD   volatile uint32_t   344
      RESPCMD   const volatile uint32_t   24
      RESP1   const volatile uint32_t   2304
      RESP2   const volatile uint32_t   0
      RESP3   const volatile uint32_t   0
      RESP4   const volatile uint32_t   0
      DTIMER   volatile uint32_t   1000000
      DLEN   volatile uint32_t   512
      DCTRL   volatile uint32_t   144
      DCOUNT   const volatile uint32_t   512
      STA   const volatile uint32_t   69632
      ICR   volatile uint32_t   0
      MASK   volatile uint32_t   282
      ACKTIME   volatile uint32_t   0
      RESERVED0   uint32_t [3]   0x50062444
      IDMACTRL   volatile uint32_t   1
      IDMABSIZE   volatile uint32_t   0
      IDMABASE0   volatile uint32_t   537525452
      IDMABASE1   volatile uint32_t   0
      RESERVED1   uint32_t [8]   0x50062460
      FIFO   volatile uint32_t   0
   clkfreq   uint32_t   48000000
   buf   uint8_t [512]   0x20000da0 <SDCD1+72>
n   uint32_t   1
resp   uint32_t *   0x2009f42c
Thanks for the help
282 (0x11A) means that the problem occurred on a write but it could have occurred on a read because the code is very similar.
Could you check your IRQ priority for SDMMC into NVIC? that problem makes no sense, I suspect there is something wrong with that (IRQ preempting the critical zone and make that check fail). Priorities 0 and 1 can preempt the kernel, 2 is reserved so 3..15 should be used.
sntnjrg
Post by sntnjrg »
I'm sorry, I'm a bit puzzled and I don't know if I'm answering your question (I'm newbie).
In mcuconf.h file, the value is:
#define STM32_IRQ_SDMMC1_PRIORITY           9
In chibios_stable-20.3.x/os/hal/ports/STM32/STM32L4xx+/platform.mk file, you can be found the following definition:
include $(CHIBIOS)/os/hal/ports/STM32/LLD/SDMMCv2/driver.mk
In chibios_stable-20.3.x/os/hal/ports/STM32/LLD/SDMMCv2/stm32_sdmmc1.inc file, the following is found:
static inline void sdmmc1_irq_init(void) {
#if STM32_SDMMC1_IS_USED
  nvicEnableVector(STM32_SDMMC1_NUMBER, STM32_IRQ_SDMMC1_PRIORITY);
static inline void sdmmc1_irq_deinit(void) {
  nvicDisableVector(STM32_SDMMC1_NUMBER);
In chibios_stable-20.3.x/os/hal/ports/STM32/LLD/SDMMCv2/stm32_sdmmc2.inc file, the following is found:
static inline void sdmmc2_irq_init(void) {
#if STM32_SDMMC2_IS_USED
  nvicEnableVector(STM32_SDMMC2_NUMBER, STM32_IRQ_SDMMC2_PRIORITY);
static inline void sdmmc2_irq_deinit(void) {
  nvicDisableVector(STM32_SDMMC2_NUMBER);
Thanks for the help.
Try putting -DCORTEX_SIMPLIFIED_PRIORITY=1 in your makefile (UDEFS and UADEFS) and see if it helps with your problem.
sntnjrg
Post by sntnjrg »
The same problem still exists: MASK volatile uint32_t 282
sdcp   SDCDriver *   0x20000dd8 <SDCD1>
   vmt   const struct SDCDriverVMT *   0x8016ebc <sdc_vmt>
   cid   uint32_t [4]   0x20000de0 <SDCD1+8>
   csd   uint32_t [4]   0x20000df0 <SDCD1+24>
   config   const SDCConfig *   0x8016fe4 <sdc_default_cfg>
   errors   sdcflags_t   4
      ARG   volatile uint32_t   1562270
   buf   uint8_t [512]   0x20000e20 <SDCD1+72>
n   uint32_t   1
I attach some photos of the reader and the wiring.
Could it be a reader hardware problem?
Another strange thing is that when I make a tree it doesn't always work and it doesn't list all the files.
ChibiOS/RT Shell
ch> tree
FS: 233482 free clusters with 64 sectors (32768 bytes) per cluster
ch> tree
ch> tree
/SYSTEM~1/INDEXE~1
/SYSTEM~1/WPSETT~1.DAT
/080720~2.TXT
ch> tree
/SYSTEM~1/INDEXE~1
ch> tree
/SYSTEM~1/INDEXE~1
/080720~2.TXT
ch> tree
ch> tree
/SYSTEM~1/INDEXE~1
ch> tree
/SYSTEM~1/INDEXE~1
/080720~2.TXT
ch> tree
/SYSTEM~1/INDEXE~1
ch>
Thanks you
sntnjrg
Post by sntnjrg »
In order for you to better observe the problem, I have adapted this example for the STM32L4R5ZI-NUCLEO144 board model:
https://github.com/ChibiOS/ChibiOS/tree/master/testhal/STM32/STM32F4xx/SDC
I'm newbie and my code may be wrong. With this adaptation, I minimize the error and you can see the problem. I'm attaching the adaptation.
When you run the following command:
ChibiOS/RT Shell
ch> sdc all
Connecting... OK
Card Info
CSD      : 400E0032 5B590000 39BF7F80 0A4000AC
CID      : 02544D53 45303847 22C02CFA A100F1DC
Mode     : SDV20
Capacity : 7392MB
Single block aligned read performance:           681 blocks/S, 348672 bytes/S
16 sequential blocks aligned read performance:   9840 blocks/S, 5038080 bytes/S
Single block unaligned read performance:         906 blocks/S, 463872 bytes/S
16 sequential blocks unaligned read performance: 672 blocks/S, 344064 bytes/S
Writing...OK
Reading...OK
Writing...OK
Reading...OK
sdcp->sdmmc->MASK has a value has a value different than 0. When I pause the execution, I notice the following in the stack:
SDC-RT-STM32L4R5ZI-NUCLEO144 (OpenOCD, Flash and Run) [GDB Hardware Debugging]
   ch.elf
      Thread #1 (Suspended : Signal : SIGINT:Interrupt)
         _idle_thread() at chcore_v7m.h:774 0x8009be0
         _port_thread_start() at chcoreasm_v7m.S:210 0x80002ba
   arm-none-eabi-gdb (8.3.0.20190703)
In the editor, the cursor stays on the next line:
 * @brief   Enters an architecture-dependent IRQ-waiting mode.
 * @details The function is meant to return when an interrupt becomes pending.
 *          The simplest implementation is an empty function or macro but this
 *          would not take advantage of architecture-specific power saving
 *          modes.
 * @note    Implemented as an inlined @p WFI instruction.
__STATIC_FORCEINLINE void port_wait_for_interrupt(void) {
#if CORTEX_ENABLE_WFI_IDLE == TRUE
  __WFI();
} // <-- Cursor here
SDC-RT-STM32L4R5ZI-NUCLEO144.zip
(17.15 KiB) Downloaded 403 times
How many times do you need to run that command to see the problem? I am trying on an STM32L4R9AI-Discovery and it never happens.
I added a demo here: /chibios_trunk/testhal/STM32/multi/SDMMC
It is normal to find the cursor in port_wait_for_interrupt(), it is within the idle thread loop. It means all other threads are sleeping.
Edit: it was an STM32L4R9 but it makes no difference.
