I fixed the issue in all STM32 drivers and in the template, not tested it yet but should be fine. It had no impact on HLD because the type is defined in the LLD.
Now ADCv1...ADCv5 all have the same errors handling code, things diverged a bit with time.
STM32H7 ADCv4 patches Topic is solved
Re: STM32H7 ADCv4 patches
I come back with ADCv4 patches, split in these parts :
° 1-adcv4_awd_fixes.patch
fixes several typos and misses with THR and AWD register copy.
° 2-adcv4_testhal_fixes.patch
fixes adc driver now check PWR_CR2_MONEN if VBAT or/and TEMP sensor is initialized
fixes cfgr need ADC_CFGR_CONT_ENABLED if DEPTH > 1 and/or continous mode is used
° 3-dualmode_fixes.patch
fixes missing ADC12_CCR_DUAL bit setting
° 4-isrhook_fixes.patch
that part was in the patch that was proposed here :
https://forum.chibios.org/viewtopic.php?f=35&t=5525&sid=0a67776478b52a263564251b4a1f9ddd#p39438
don't know if it's still relevant, but did not want to clear it silently
° 5-sample-wide_proposal.patch
this is a proposal to enable more that 16 bits wide sample, when oversampling is activated.
Sorry for the work for reviewing all of that ...
Alexandre
Alexandre
- adcv4_patches_over_trunck_26_04_21.zip
- several adcv4 patches to fix awd, dual_mode, testhal and wide_sample proposal
- (5.68 KiB) Downloaded 492 times
Committed in trunk patches 1..4. I have a request for patch 5, I suggest making a single configuration with samples size (STM32_ADC_SAMLES_SIZE: 8, 16, 32) and perform all checks based on the value. In addition, everything should be ported to 20.3 too.
Could you take care of this when you have some time?
here is a proposal for unified ADC_SAMPLES_SIZE definition above actual trunk, and portage of the whole thing to 20.3.
I have tested with 8, 16, 32 bits in continuous and one shot mode without issue.
It is not possible to port the patch to 20.3 without using your new event_mask, so
ADCv4/hal_adc_lld.{h,c} are identical in 20.3 and trunk after both patches applied.
One thing to remember is the behavior of driver concerning CONT bit, some drivers take care of it, and some don't.
ADCv4 leave the CONT bit management to the user : it should be set in continuous mode, and in one_shot mode when DEPTH is > 1.
another approach could have been to let the driver manage CONT bit, only when DISCEN bit is not set in the provided cfgr value.
Alexandre
Alexandre
- unified_adcv4_sample_size_over_20.3.patch.zip
- (4.35 KiB) Downloaded 462 times
- unified_adcv4_sample_size_over_trunk.zip
- (1.88 KiB) Downloaded 483 times
Hi Alex,
I committed the patch on trunk then ported the whole trunk driver to 20.x, no point in keeping 2 versions around.
Could you give it a try?
mikeprotts
- Has thanked: 19 times
- Been thanked: 31 times
I've just been taking a look at this (using an STM32H743 old style). The documents suggest that the VREF and TS values have to be taken from ADC3, but the sample uses ADC1. Also the channels need to be changed to 19 (VREF) & 18 (TS), using SMPR2.
When I run the testhal/STM32/mutli/ADC sample as provided, it seems to run ok, but looks like the values collected are random, varying too much to be realistic VREF.
I changed the testhal sample to use ADC3 (portab.h) and correct channels (portab.c), but it halts in the error callback, with err = 1 (ADC_ERR_DMAFAILURE)
Has anyone tried ADC3? Any suggestion as to how to diagnose the DMA failure?
I'm using the latest trunk, arm-none-eabi-gcc 7.3.1.
Cheers
Mike
(gdb) where
#0 0x0800335c in chSysHalt (reason=0x8006420 "it happened") at ../../../../os/rt/src/chsys.c:222
#1 0x080059ce in adcerrorcallback (adcp=0x24000038 <ADCD3>, err=1) at main.c:72
#2 0x08001734 in adc_lld_serve_bdma_interrupt (adcp=0x24000038 <ADCD3>, flags=8)
at ../../../../os/hal/ports/STM32/LLD/ADCv4/hal_adc_lld.c:253
#3 0x08001f94 in Vector244 () at ../../../../os/hal/ports/STM32/LLD/BDMAv1/stm32_bdma.c:125
#4 <signal handler called>
#5 0x55555554 in ?? ()
Cheers
Mike
ADC3 uses BDMA, is the buffer placed in a RAM accessible by BDMA?
mikeprotts
That seems to be the problem - need to allocate to ram4. I need to check the values are correct as I seem to have a temperature of 3810.46'C, but VREF looks good at 3295 mV. I suspect my calculations are off as they are unchanged from the STM32F7 code.
What's the preferred option for portable allocation - I use gcc and:
I should be able to generate a small patch for this demo, so I'd prefer to make it fit the usual pattern.
Thanks
Mike
adcsample_t samples1[CACHE_SIZE_ALIGN(adcsample_t, ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH)]
__attribute__ ((section (".ram4")));
Thanks
Mike
It is best to include ccportab.h and use CC_SECTION() macro, it is compiler-independent, place it before the buffer declaration. The section to use would be .ram4_clear, you want the RAM to be initialized.
