STM32F103 LibUsb
Re: STM32F103 LibUsb
You should single step in ASM through that switch/case and see what happens exactly.
goahunter
Post by goahunter »
Ok so to fix the problem, the following line of code was changed to directly use the LLD
      /* Initiate next receive */
       usbPrepareReceive(usbp, EP_OUT, receiveBuf, 62);
       chSysLockFromIsr();
       usbStartReceiveI(usbp, EP_OUT);
       chSysUnlockFromIsr();
to
usb_lld_read_packet_buffer(usbp, ep, receiveBuf, 62);
      usb_lld_start_out(usbp, ep);
That looks more like a workaround than a solution, low level functions are not meant to be called directly. It is possible that some error condition prevents the high level functions to call the low level but you should address the reason not just bypass the check.
