The RTC driver topic
gallegojm
Re: The RTC driver topic
Post by gallegojm »
As I explain in an other topic, I wrote a NTP client to set the clock of my Olimex STM32-E407 board and use RTC driver
The code is at Github.
But the clock was too fast
This screen show that it was leading 80 seconds every 10 minutes!
RTC drift
RTC drift
To slow the clock, I have to modify the value of STM32_RTC_PRESS_VALUE in file chibios3\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.h
For the modification to be effective, I have to unplug the board and reconnect it. This is because the RTC registers of the STM32F407 microcontroller are write-protected after the power up (see DM000310020.pdf , page 788). A system reset do not affect this protection.
I set STM32_RTC_PRESS_VALUE to 1024 x 1.133 = 1160
The clock is now accurate.
gallegojm
Post by gallegojm »
in order to adjust the value of the RTC PRESS divider without modifying the code I propose to make the following change in the file chibios3\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.h :
Replace
 * @brief   RTC PRESS divider initialization.
 * @note    The default is calculated for a 32768Hz clock.
#if !defined(STM32_RTC_PRESS_VALUE) || defined(__DOXYGEN__)
#define STM32_RTC_PRESS_VALUE               1024
by
#if STM32_LSECLK
#define STM32_RTC_PRESS_VALUE              (( STM32_LSECLK + 16 ) / 32 )
#else
In this way, simply correcting the value of the RTC oscillator in the corresponding board.h file would give the good value for the RTC PRESS divider
barthess
Post by barthess »
1)
gallegojm wrote:it was leading 80 seconds every 10 minutes!
Are you absolutely sure your RTC uses external crystal (not LSI)?
2) This configuration option looks kind of hardcode. RTC in STM32 has special calibration "knobs"
for that purpose.
gallegojm wrote:in order to adjust the value of the RTC PRESS divider without modifying the code I propose to make the following change in the file chibios3\os\hal\ports\STM32\LLD\RTCv2\rtc_lld.h :
Replace
by
#if STM32_LSECLK
#else
It is still overridden by mcuconf.h which always contains the definition. The macro should check the LSE enable switch anyway, it could be disabled and not started.
gallegojm
Post by gallegojm »
Hi Barthess and Giovanny
Thanks to your comments, I realized:
- that I was trying to solve the problem from the wrong end. :?
- that I forgot that a crystal oscillator can not be so far from his nominal frequency (very bad for an old electronic engineer :cry: )
- that I had to study a little more the data sheet of the mcu :roll:
After these three steps, I add the following code in the main routine:
  uint32_t reg;
  chprintf( (BaseSequentialStream *) & SDU2, "RTC info:\r\n" );
  chprintf( (BaseSequentialStream *) & SDU2, "RTC clock %s\r\n",
            ( RCC_BDCR_RTCEN ? "enable" : "disable" ));
  reg = ( RCC->BDCR & STM32_RTCSEL_MASK ) >> 8;
  if( reg == 0 )
    chprintf( (BaseSequentialStream *) & SDU2, "No" );
  else if( reg == 1 )
    chprintf( (BaseSequentialStream *) & SDU2, "LSE" );
  else if( reg == 2 )
    chprintf( (BaseSequentialStream *) & SDU2, "LSI" );
  else
    chprintf( (BaseSequentialStream *) & SDU2, "HSE" );
  chprintf( (BaseSequentialStream *) & SDU2, " clock used as the RTC clock\r\n" );
And got this result:
RTC info:
RTC clock enable
LSI clock used as the RTC clock
So, how can I oblige the mcu to use the external crystal oscillator?
You need:
#define STM32_LSE_ENABLED                   TRUE
#define STM32_RTCSEL                        STM32_RTCSEL_LSE
barthess
Post by barthess »
Add grain of salt to Giovanni's message:
And do not forget to remove RTC battery and poweroff board to apply changes.
gallegojm
Post by gallegojm »
Thank you to both of you.
So I modify those define in file mcuconf.h
#define STM32_LSI_ENABLED                   FALSE
and it works fine.
The next step would be to test accuracy on larger periods of time and play with the RTC digital calibration capability.
Note there was a mistake in the code I write to test the values of the RCC_BDCR register:
The test of RTCEN bit always return true.
Correct code is:
  chprintf((BaseSequentialStream *) & SDU2, "RTC clock %s\r\n",
           (( reg & RCC_BDCR_RTCEN ) ? "enable" : "disable" ));
Jean-Michel
(I have difficulties with the radio connection to internet those days that explain the late response)
gallegojm
Post by gallegojm »
Hi
I had two problems running rtcConvertDateTimeToFAT()
First, I think the code that performs the calculation of seconds, minutes and hours is not correct.
I replace
  tmp = timespec->millisecond / 1000U;
  sec = tmp % 60U;
  min = (tmp - sec) % 3600U;
  hour = ((tmp - sec) - (min * 60U)) / 3600U;
with
  sec = timespec->millisecond / 1000U;
  hour = sec / 3600U;
  sec %= 3600U;
  min = sec / 60U;
  sec %= 60U;
to get the correct result.
Second, is there a way to disable DST? (in case of a country that do not use daylight saving)
Jean-Michel
barthess
Post by barthess »
1) That's my fault. Giovanni, can I commit fix now or you still perform release related work on trunk?
2) Just set DST to 0 and forget.
