ctxp corrupted in _port_irq_epilogue
AndreR
Re: ctxp corrupted in _port_irq_epilogue
Post by AndreR »
Can't believe that a field-oriented motor control is an unusual project ;)
I need those fast IRQs to reduce IRQ latency as much as possible. And if you state ChibiOS is able to use fast IRQs, I take you word for granted.
Anyway, great to hear you are working on a fix. Do you still need the compilable project? Sounds like you managed to run it.
Nope, I just analyzed the code section, there are two potential issues but I am not yet sure because the Cortex-M is very complex at that level and the documentation is filled of errors.
AndreR
Post by AndreR »
Oh, I just recognized that the STM32F3xx firmware library is not part of ChibiOS. I use it as my HAL abstraction, because I have less porting work with it.
I am downloading ChibiStudio right now (ETA: 30mins) and will try to compile my example there, eventually adding some missing files/vectors.
AndreR
Post by AndreR »
There you go. I inserted the code into the STM32F303-DISCOVERY demo project. I don't have that board myself, so I hope I ported everything correct.
ARMCM4-STM32F303-DISCOVERY.7z
F303-DISCOVERY MWE
(45.66 KiB) Downloaded 407 times
Could you give a try to the following fix?
    ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
                 2011,2012,2013 Giovanni Di Sirio.
    This file is part of ChibiOS/RT.
    ChibiOS/RT is free software; you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation; either version 3 of the License, or
    (at your option) any later version.
    ChibiOS/RT is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    A special exception to the GPL can be applied should you wish to distribute
    a combined work that includes ChibiOS/RT, without being obliged to provide
    the source code for any proprietary components. See the file exception.txt
    for full details of how and when the exception can be applied.
 * @file    GCC/ARMCMx/chcore_v7m.c
 * @brief   ARMv7-M architecture port code.
 * @addtogroup ARMCMx_V7M_CORE
#include "ch.h"
/* Port interrupt handlers.                                                  */
 * @brief   System Timer vector.
 * @details This interrupt is used as system tick.
 * @note    The timer must be initialized in the startup code.
CH_IRQ_HANDLER(SysTickVector) {
  CH_IRQ_PROLOGUE();
  chSysLockFromIsr();
  chSysTimerHandlerI();
  chSysUnlockFromIsr();
  CH_IRQ_EPILOGUE();
#if !CORTEX_SIMPLIFIED_PRIORITY || defined(__DOXYGEN__)
 * @brief   SVCall vector.
 * @details The SVCall vector is used for exception mode re-entering after a
 *          context switch.
 * @note    The SVCallVector vector is only used in advanced kernel mode.
void SVCallVector(void) {
  struct extctx *ctxp;
#if CORTEX_USE_FPU
  /* Enforcing unstacking of the FP part of the context.*/
  SCB_FPCCR &= ~FPCCR_LSPACT;
  /* Current PSP value.*/
  asm volatile ("mrs     %0, PSP" : "=r" (ctxp) : : "memory");
  /* Discarding the current exception context and positioning the stack to
     point to the real one.*/
  ctxp++;
  /* Restoring real position of the original stack frame.*/
  asm volatile ("msr     PSP, %0" : : "r" (ctxp) : "memory");
  port_unlock_from_isr();
#endif /* !CORTEX_SIMPLIFIED_PRIORITY */
#if CORTEX_SIMPLIFIED_PRIORITY || defined(__DOXYGEN__)
 * @brief   PendSV vector.
 * @details The PendSV vector is used for exception mode re-entering after a
 *          context switch.
 * @note    The PendSV vector is only used in compact kernel mode.
void PendSVVector(void) {
#if CORTEX_USE_FPU
  ctxp++;
#endif /* CORTEX_SIMPLIFIED_PRIORITY */
/* Port exported functions.                                                  */
 * @brief   Port-related initialization code.
void _port_init(void) {
  /* Initialization of the vector table and priority related settings.*/
  SCB_VTOR = CORTEX_VTOR_INIT;
  SCB_AIRCR = AIRCR_VECTKEY | AIRCR_PRIGROUP(CORTEX_PRIGROUP_INIT);
  /* Initialization of the system vectors used by the port.*/
  nvicSetSystemHandlerPriority(HANDLER_SVCALL,
    CORTEX_PRIORITY_MASK(CORTEX_PRIORITY_SVCALL));
  nvicSetSystemHandlerPriority(HANDLER_PENDSV,
    CORTEX_PRIORITY_MASK(CORTEX_PRIORITY_PENDSV));
  nvicSetSystemHandlerPriority(HANDLER_SYSTICK,
    CORTEX_PRIORITY_MASK(CORTEX_PRIORITY_SYSTICK));
#if !CH_OPTIMIZE_SPEED
void _port_lock(void) {
  register uint32_t tmp asm ("r3") = CORTEX_BASEPRI_KERNEL;
  asm volatile ("msr     BASEPRI, %0" : : "r" (tmp) : "memory");
void _port_unlock(void) {
  register uint32_t tmp asm ("r3") = CORTEX_BASEPRI_DISABLED;
 * @brief   Exception exit redirection to _port_switch_from_isr().
void _port_irq_epilogue(void) {
  port_lock_from_isr();
  if ((SCB_ICSR & ICSR_RETTOBASE) != 0) {
#if CORTEX_USE_FPU
    /* Enforcing a lazy FPU state save. Note, it goes in the original
       context because the FPCAR register has not been modified.*/
    asm volatile ("vmrs    APSR_nzcv, FPSCR" : : : "memory");
    /* Adding an artificial exception return context, there is no need to
       populate it fully.*/
    ctxp--;
    ctxp->xpsr = (regarm_t)0x01000000;
    /* The exit sequence is different depending on if a preemption is
       required or not.*/
    if (chSchIsPreemptionRequired()) {
      /* Preemption is required we need to enforce a context switch.*/
      ctxp->pc = (void *)_port_switch_from_isr;
    else {
      /* Preemption not required, we just need to exit the exception
         atomically.*/
      ctxp->pc = (void *)_port_exit_from_isr;
    /* Note, returning without unlocking is intentional, this is done in
       order to keep the rest of the context switch atomic.*/
    return;
 * @brief   Post-IRQ switch code.
 * @details Exception handlers return here for context switching.
#if !defined(__DOXYGEN__)
__attribute__((naked))
void _port_switch_from_isr(void) {
  dbg_check_lock();
  chSchDoReschedule();
  dbg_check_unlock();
  asm volatile ("_port_exit_from_isr:" : : : "memory");
  asm volatile ("svc     #0");
#else /* CORTEX_SIMPLIFIED_PRIORITY */
  SCB_ICSR = ICSR_PENDSVSET;
  port_unlock();
  while (TRUE)
 * @brief   Performs a context switch between two threads.
 * @details This is the most critical code in any port, this function
 *          is responsible for the context switch between 2 threads.
 * @note    The implementation of this code affects <b>directly</b> the context
 *          switch performance so optimize here as much as you can.
 * @param[in] ntp       the thread to be switched in
 * @param[in] otp       the thread to be switched out
void _port_switch(Thread *ntp, Thread *otp) {
  asm volatile ("push    {r4, r5, r6, r7, r8, r9, r10, r11, lr}"
                : : : "memory");
#if CORTEX_USE_FPU
  asm volatile ("vpush   {s16-s31}" : : : "memory");
  asm volatile ("str     sp, [%1, #12]                          \n\t"
                "ldr     sp, [%0, #12]" : : "r" (ntp), "r" (otp));
#if CORTEX_USE_FPU
  asm volatile ("vpop    {s16-s31}" : : : "memory");
  asm volatile ("pop     {r4, r5, r6, r7, r8, r9, r10, r11, pc}"
                : : : "memory");
 * @brief   Start a thread by invoking its work function.
 * @details If the work function returns @p chThdExit() is automatically
 *          invoked.
void _port_thread_start(void) {
  chSysUnlock();
  asm volatile ("mov     r0, r5                                 \n\t"
                "blx     r4                                     \n\t"
                "bl      chThdExit");
The code is simplified but it comes with a small overhead caused by extra FPU context saves and restores. I am thinking to a different approach but this could take a while and the advantage is not certain.
AndreR
Post by AndreR »
It took a while to find some time for testing, but it looks good now :)
The previous version crashed after 10s, the "patched" one you provided is already running for an hour by now. My CPU load measurement did not show a significant increase (<0.1%).
Thanks for testing, I am glad the problem is solved. I found two distinct race conditions caused by fast IRQs so the whole thing has been very useful.
jbrandmeyer_bwp
Post by jbrandmeyer_bwp »
The latest version doesn't seem to be working for me.
I'm concerned about the implementation of the fake return context being added in _port_irq_epilogue(). The Epilogue code isn't checking to see what kind of fake context to add. In particular, if CONTROL.FPCA was not set when the exception (IRQ) was taken, then only a standard context was stacked by the hardware. It doesn't even reserve space for the FPU context, since the caller was not using it. Thus, when the IRQ returns, the stack gets clobbered when it unstacks only part of the additional context.
It may be possible for the PORT_IRQ_EPILOGUE() to pass the relevant information to _port_irq_epilogue() via gcc's __builtin_return_address().
How much regression testing does the FPU context handling code get? Do you have tests for each case of FPU usage? Ie, user tasks, virtual timer callbacks, OS-aware ISR's, fast ISRs, and combinations thereof?
The FPCA bit is set in the startup file, the scenario where a "short" context is pushed on the stack is not handled at all, it was the same in the previous iterations.
The reason for this is that all the added tests on short/long contexts would take more time than just using always long contexts.
The FPU_STORM demo is what is used for FPU testing, it randomly goes into all the possible cases so it is a long duration test.
jbrandmeyer_bwp
Sorry for the delayed reply. The issue is that I have the FPU interrupt enabled, with behavior that triggers a processor reset. The new _port_irq_epilogue() does not forcefully disable lazy unstacking to avoid race conditions with FPCCR and FPCAR. However, the artificial context does not have a valid fpscr specified. The unstacking loads a garbage fpscr which triggers the FPU exception.
Initializing the artificial exception context's fpscr member from the FPDSCR cleanly solves the problem.
