STM32f103VET6 Bootloader jump problem.
Re: STM32f103VET6 Bootloader jump problem.
I cannot give advice about this, you have to discover where it goes in exception.
franek.bmw
Post by franek.bmw »
It goes to exception at the and of this function, in Jump_To_Application();
void jumpToUser(uint32_t address) {
   typedef void (*pFunction)(void);
   pFunction Jump_To_Application;
   /* variable that will be loaded with the start address of the application */
   vu32* JumpAddress;
   const vu32* ApplicationAddress = (vu32*) address;
   if (((*(unsigned long*)address) & 0x2FFE0000 ) == 0x20000000)
      /* get jump address from application vector table */
      JumpAddress = (vu32*) ApplicationAddress[1];
      /* load this address into function pointer */
      Jump_To_Application = (pFunction) JumpAddress;
      /* Clear pending interrupts just to be on the safe side*/
      SCB_ICSR = ICSR_PENDSVCLR;
      /* Disable all interrupts */
      uint8_t i;
      for(i=0; i<8; i++)
         NVIC->ICER[i] = NVIC->IABR[i];
      /* set stack pointer as in application's vector table */
      __set_MSP((u32) (ApplicationAddress[0]));
Try to single step instruction by instruction. There must be one that causes the crash.
franek.bmw
I found bug! :-) In my app I make in RAM fifo which overflow memory. When I reduce size of fifo all is good.
So I have a question. Probably when processor jump from bootloader to app in RAM remain some unnecessarily variables. It is possible to release this area of RAM?
BTW: If my application was written in CHIBIOS, I would have found this problem much earlier. But when I wrote it, I did not know yet CHIBIOS ;-)
When you jump to the application the bootloader is no more active (I assume), you can use all the RAM.
franek.bmw
So what can caused this lack of memory?
Franek
Sorry, I don't understand...
franek.bmw
When I have only app, my fifo size could be 500B, when I have bootloader too, my fifo in app could be only 120B. Why?
You are asking me things specific to your setup, how I am supposed to answer?
I can only recommend to study the map files in order to understand the memory organization of your application, then eventually evaluate changes to the .ld scripts.
franek.bmw
Could you give me some clue, if I send to you my linker script or map files?
