New Makefile Topic is solved
Moderators: tfAteba, utzig
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Re: New Makefile
Postby tfAteba » Tue Oct 31, 2017 9:48 pm
Hello Giovanni,
I have align my local trunk to your last modification, and I have modify the AVR/RT-ARDUINO-MEGA/main.c to also exucute the oslib test suite.
For me the test suite still fails, here is an output of the execution:
=== Test Sequence 1 (Information)
--- Test Case 1.1 (Kernel Info)
--- Product:                   ChibiOS/RT
--- Stable Flag:               0
--- Version String:            5.0.0
--- Major Number:              5
--- Minor Number:              0
--- Patch Number:              0
--- Result: SUCCESS
--- Test Case 1.2 (Kernel Settings)
--- CH_CFG_ST_RESOLUTION:      16
--- CH_CFG_ST_FREQUENCY:       15624
--- CH_CFG_ST_TIMEDELTA:       2
--- CH_CFG_TIME_QUANTUM:       0
--- CH_CFG_MEMCORE_SIZE:       128
--- CH_CFG_NO_IDLE_THREAD:     0
--- CH_CFG_OPTIMIZE_SPEED:     1
--- CH_CFG_USE_TM:             0
--- CH_CFG_USE_REGISTRY:       1
--- CH_CFG_USE_WAITEXIT:       1
--- CH_CFG_USE_SEMAPHORES:     1
--- CH_CFG_USE_SEMAPHORES_PRI: 0
--- CH_CFG_USE_MUTEXES:        1
--- CH_CFG_USE_MUTEXES_RECURS: 0
--- CH_CFG_USE_CONDVARS:       1
--- CH_CFG_USE_CONDVARS_TIMEO: 1
--- CH_CFG_USE_EVENTS:         1
--- CH_CFG_USE_EVENTS_TIMEOUT: 1
--- CH_CFG_USE_MESSAGES:       1
--- CH_CFG_USE_MESSAGES_PRI:   0
--- CH_CFG_USE_MAILBOXES:      1
--- CH_CFG_USE_MEMCORE:        1
--- CH_CFG_USE_HEAP:           1
--- CH_CFG_USE_MEMPOOLS:       1
--- CH_CFG_USE_DYNAMIC:        1
--- CH_DBG_STATISTICS:         0
--- CH_DBG_SYSTEM_STATE_CHECK: 0
--- CH_DBG_ENABLE_CHECKS:      0
--- CH_DBG_ENABLE_ASSERTS:     0
--- CH_DBG_TRACE_MASK:         255
--- CH_DBG_TRACE_BUFFER_SIZE:  128
--- CH_DBG_ENABLE_STACK_CHECK: 0
--- CH_DBG_FILL_THREADS:       0
--- CH_DBG_THREADS_PROFILING:  0
--- Result: SUCCESS
=== Test Sequence 2 (System layer and port interface)
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Test Case 2.4 (System Tick Counter functionality)
--- Result: SUCCESS
=== Test Sequence 3 (Threads Functionality)
--- Test Case 3.1 (Thread Sleep functionality)
--- Result: SUCCESS
--- Test Case 3.2 (Ready List functionality, threads priority order)
--- Result: SUCCESS
--- Test Case 3.3 (Priority change test)
--- Result: SUCCESS
--- Test Case 3.4 (Priority change test with Priority Inheritance)
--- Result: SUCCESS
=== Test Sequence 4 (Suspend/Resume)
--- Test Case 4.1 (Suspend and Resume functionality)
--- Result: SUCCESS
=== Test Sequence 5 (Counter Semaphores)
--- Test Case 5.1 (Semaphore primitives, no state change)
--- Result: SUCCESS
--- Test Case 5.2 (Semaphore enqueuing test)
--- Result: SUCCESS
--- Test Case 5.3 (Semaphore timeout test)
--- Result: SUCCESS
--- Test Case 5.4 (Testing chSemAddCounterI() functionality)
--- Result: SUCCESS
--- Test Case 5.5 (Testing chSemWaitSignal() functionality)
--- Result: SUCCESS
--- Test Case 5.6 (Testing Binary Semaphores special case)
--- Result: SUCCESS
=== Test Sequence 6 (Mutexes, Condition Variables and Priority Inheritance)
--- Test Case 6.1 (Priority enqueuing test)
--- Result: SUCCESS
--- Test Case 6.2 (Priority return verification)
--- Result: SUCCESS
--- Test Case 6.3 (Repeated locks, non recursive scenario)
--- Result: SUCCESS
--- Test Case 6.4 (Condition Variable signal test)
--- Result: SUCCESS
--- Test Case 6.5 (Condition Variable broadcast test)
--- Result: SUCCESS
--- Test Case 6.6 (Condition Variable priority boost test)
--- Result: SUCCESS
=== Test Sequence 7 (Synchronous Messages)
--- Test Case 7.1 (Messages Server loop)
--- Result: SUCCESS
=== Test Sequence 8 (Event Sources and Event Flags)
--- Test Case 8.1 (Events registration)
--- Result: SUCCESS
--- Test Case 8.2 (Event Flags dispatching)
--- Result: SUCCESS
--- Test Case 8.3 (Events Flags wait using chEvtWaitOne())
--- Result: SUCCESS
--- Test Case 8.4 (Events Flags wait using chEvtWaitAny())
--- Result: SUCCESS
--- Test Case 8.5 (Events Flags wait using chEvtWaitAll())
--- Result: SUCCESS
--- Test Case 8.6 (Events Flags wait timeouts)
--- Result: SUCCESS
--- Test Case 8.7 (Broadcasting using chEvtBroadcast())
--- Result: SUCCESS
=== Test Sequence 9 (Dynamic threads)
--- Test Case 9.1 (Threads creation from Memory Heap)
--- Result: FAILURE (#5 [ABC] "thread creation not failed")
--- Test Case 9.2 (Threads creation from Memory Pool)
--- Result: SUCCESS
=== Test Sequence 10 (Benchmarks)
--- Test Case 10.1 (Messages performance #1)
--- Score : 32850 msgs/S, 65700 ctxswc/S
--- Result: SUCCESS
--- Test Case 10.2 (Messages performance #2)
--- Score : 25353 msgs/S, 50706 ctxswc/S
--- Result: SUCCESS
--- Test Case 10.3 (Messages performance #3)
--- Result: SUCCESS
--- Test Case 10.4 (Context Switch performance)
--- Score : 91616 ctxswc/S
--- Result: SUCCESS
--- Test Case 10.5 (Threads performance, full cycle)
--- Score : 20328 threads/S
--- Result: SUCCESS
--- Test Case 10.6 (Threads performance, create/exit only)
--- Score : 26932 threads/S
--- Result: SUCCESS
--- Test Case 10.7 (Mass reschedule performance)
--- Score : 7983 reschedules/S, 47898 ctxswc/S
--- Result: SUCCESS
--- Test Case 10.8 (Round-Robin voluntary reschedule)
--- Score : 62680 ctxswc/S
--- Result: SUCCESS
--- Test Case 10.9 (Virtual Timers set/reset performance)
--- Score : 46214 timers/S
--- Result: SUCCESS
--- Test Case 10.10 (Semaphores wait/signal performance)
--- Score : 243316 wait+signal/S
--- Result: SUCCESS
--- Test Case 10.11 (Mutexes lock/unlock performance)
--- Score : 123300 lock+unlock/S
--- Result: SUCCESS
--- Test Case 10.12 (RAM Footprint)
--- System: 57 bytes
--- Thread: 32 bytes
--- Timer : 12 bytes
--- Semaph: 5 bytes
--- Mutex : 8 bytes
--- CondV.: 4 bytes
--- EventS: 2 bytes
--- EventL: 7 bytes
--- MailB.: 19 bytes
--- Result: SUCCESS
Final result: FAILURE
*** ChibiOS OS Library Test Suite
*** Compiled:     Oct 31 2017 - 21:37:40
*** Platform:     AVR
*** Test Board:   Arduino Mega
=== Test Sequence 1 (Mailboxes)
--- Test Case 1.1 (Mailbox normal API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 1.2 (Mailbox I-Class API, non-blocking tests)
--- Result: SUCCESS
--- Test Case 1.3 (Mailbox timeouts)
--- Result: SUCCESS
=== Test Sequence 2 (Memory Pools)
--- Test Case 2.1 (Loading and emptying a memory pool)
--- Result: SUCCESS
--- Test Case 2.2 (Loading and emptying a guarded memory pool without waiting)
--- Result: SUCCESS
--- Test Case 2.3 (Guarded Memory Pools timeout)
--- Result: SUCCESS
=== Test Sequence 3 (Memory Heaps)
--- Test Case 3.1 (Allocation and fragmentation)
--- Result: SUCCESS
--- Test Case 3.2 (Default Heap)
--- Result: SUCCESS
Final result: SUCCESS
There is a problem at test case 9. when threads have to be created from heap.
Has thanked: 1146 times
Been thanked: 960 times
Re: New Makefile
Postby Giovanni » Wed Nov 01, 2017 5:45 pm
I will look into this, it looks something different. It is a good thing you are testing on a different architecture.
tfAteba
Re: New Makefile
Postby tfAteba » Wed Nov 01, 2017 7:29 pm
Thanks Giovanni,
Sorry to not be able to help further, I do not have an AVR debugger tool, I think I will by one, it could be very useful.
tfAteba
Re: New Makefile
Postby tfAteba » Sat Nov 04, 2017 12:11 pm
Hello Giovanni,
I have found the solution for the faillure of the test suite. After making a full rebuild, I had some warning that help me to understand what was going on.
Here is the warning message:
In file included from ../../../os/rt/include/ch.h:96:0,
                 from ../../../os/hal/osal/rt/osal.h:32,
                 from ../../../os/hal/include/hal.h:28,
                 from ../../../test/rt/source/test/rt_test_sequence_009.c:17:
../../../test/rt/source/test/rt_test_sequence_009.c: In function ‘rt_test_009_001_execute’:
../../../test/rt/source/test/rt_test_sequence_009.c:140:79: warning: integer overflow in expression [-Woverflow]
                                      THD_WORKING_AREA_SIZE(THREADS_STACK_SIZE * 1024),
../../../os/rt/include/chalign.h:69:13: note: in definition of macro ‘MEM_ALIGN_PREV’
   ((size_t)(p) & ~MEM_ALIGN_MASK(a))                                        \
../../../os/rt/include/chthreads.h:135:3: note: in expansion of macro ‘MEM_ALIGN_NEXT’
   MEM_ALIGN_NEXT(sizeof(thread_t) + PORT_WA_SIZE(n), PORT_STACK_ALIGN)
../../../os/rt/include/chthreads.h:135:37: note: in expansion of macro ‘PORT_WA_SIZE’
../../../test/rt/source/test/rt_test_sequence_009.c:140:38: note: in expansion of macro ‘THD_WORKING_AREA_SIZE’
So an overflow was the cause of the failure of the test sequence. By reducing the amount of heap use for the thread, the problem was resolve.
Here is the modification made on the file rt_test_sequence_009.c line 140
THD_WORKING_AREA_SIZE(THREADS_STACK_SIZE * 255),
Finally, here is the output of the test result:
*** ChibiOS/RT Test Suite
*** Compiled:     Nov  4 2017 - 11:52:39
*** Platform:     AVR
--- Stable Flag:               0
--- Major Number:              5
--- Minor Number:              0
--- Patch Number:              0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 32849 msgs/S, 65698 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Semaph: 5 bytes
--- Mutex : 8 bytes
--- CondV.: 4 bytes
--- EventS: 2 bytes
--- EventL: 7 bytes
--- Result: SUCCESS
*** Platform:     AVR
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
So some solution ca be to decrease the thread heap for all the architecture to 255 or to check in this file if we have an AVR achitecture then use 255 as heap factor size.
Maybe you have another solution?
Thanks
Re: New Makefile
Postby Giovanni » Sat Nov 04, 2017 7:28 pm
Good catch, fixed on trunk.
tfAteba
Re: New Makefile  Topic is solved
Postby tfAteba » Sat Nov 04, 2017 9:55 pm
Thanks Giovanni,
I will run the test suite on all the AVR board I have to see if everything is fine.
Thanks for your help to resolve all the recent problems.
Return to “AVR Support”
Users browsing this forum: Bing [Bot] and 99 guests
