Page 4 of 18
Re: GDISP driver
Posted: Tue Jul 31, 2012 5:49 pm
by inmarket
Just did a pull request for the back-ported ssd1289 low level driver.
As I don't have that hardware can someone please compile and test for me.
Re: GDISP driver
Posted: Tue Jul 31, 2012 5:54 pm
by Abhishek
@Tectu, the script given is just to convert the font table from the old fmt to the new format. Unfortunately. It can't generate a font table by itself!
Re: GDISP driver
by inmarket
Abhishek wrote:Since only you are under control of your code right now
, how would you go about it with your current framework?
Probably create sub-directories under halext/drivers.
The devil is in the detail and we will get the best feel for it when we first try it.
Hopefully in the next few days I get a chance to think more about it.
Re: GDISP driver
Posted: Tue Jul 31, 2012 5:55 pm
by Tectu
Dosen't anybody of you windows guys use a font generator? Abhsishek, afaik you did? Couldn't you make a few more fonts?
Re: GDISP driver
Posted: Tue Jul 31, 2012 6:00 pm
by Abhishek
@Tectu, the font generator I used supports 16bit fonts only
. However if you want to try out a new style like Comic Sans, i'll give you.
@inmarket, if you do the S6D1121, I might give it a try on Thursday.
Re: GDISP driver
Posted: Tue Jul 31, 2012 6:01 pm
by inmarket
Tectu wrote:Dosen't anybody of you windows guys use a font generator? Abhsishek, afaik you did? Couldn't you make a few more fonts?
I vagely remember microwindows (google it) use to have a bitmap font generator (at least before they switched to true-type bloat). If that is still around it could be merged with my utility previous posted to create fonts ad-infinitum.
Re: GDISP driver
Posted: Tue Jul 31, 2012 6:04 pm
by inmarket
Abhishek wrote:@Tectu, the font generator I used supports 16bit fonts only
Are you able to make this generally availble?
If copyright allows perhaps we could create a tools directory and add it to that?
Abhishek wrote:@inmarket, if you do the S6D1121, I might give it a try on Thursday.
I'll try to get to it tomorrow if my day isn't too busy.
Re: GDISP driver
Posted: Tue Jul 31, 2012 6:08 pm
by Abhishek
Get it from here:
http://reifel.org/picuserinterface/My text rendering code was based on this one.
Re: GDISP driver
Posted: Wed Aug 01, 2012 5:14 pm
by inmarket
Just added new pull request for a number updates including new low level driver s6d1121.
Re: GDISP driver
Posted: Wed Aug 01, 2012 5:25 pm
by inmarket
Thanks, it was very helpful. I have one more low level driver to do for gdisp (the Nokia6100), some testing to do and then I'll look at creating a font generator in that style. I will write it in java so that it will run on both Windows and Linux. I also need to catch up on some sleep soon
In the latest upload I have extracted the font structure definitions into a nice standalone include file so that it can also be included in any font tools written. I also included a define so that you can rebuild using up to 32 bit high fonts instead of 16 (the default).
