IAR AVR Port
Moderator: tfAteba
JetForMe
Re: IAR AVR Port
Post by JetForMe »
Fair enough.
Can you tell me what the port_switch() routine is doing? It seems to use r22/r23 and r24/r25 for something related to the stack pointer. It also doesn't save and restore all the registers, which I understand is how you speed up context switches, because the compiler saves and restores some of them. But I don't know which ones.
I'm still trying to understand what's going wrong.
I'm doing this on a Mac without a debugger. I have Windows in a VM and can debug using AVR Studio 6 (which has GCC, too), but it seemed like it would be pretty hard to get ChibiOS to build in that environment; I'd have to make a project and add all the files and I'm not sure how much work it would take to learn AVR Studio 6 and get it to build correctly. I was hoping I could figure it out with printf(), but it's hard to trace through the execution without being able to single step.
Re: IAR AVR Port
I think it has been covered in the past, the port_switch() function saves the registers defined in the intctx structure. That structure must contain all the registers that the compiler expects to not be altered by function calls plus the stack frame of port_switch() itself (usually just the return address).
This structure is architecture AND compiler dependent.
The function used registers are the only required in order to switch from thread to thread because the compiler expects the other ones to be altered anyway when calling port_switch().
The extctx structures contains all the other registers, those that are saved and restored by ISRs, this structure must describe the stack frame created by ISR functions, again this is compiler and architecture dependent.
The correct definitions of those structures is the first and most critical step in order to implement a port layer for a new architecture.
I know for sure that there are many users interested in the AVR architecture, I suggest to team up and work on the AVR support, right now the port is not actively maintained.
JetForMe
Re: IAR AVR Port
Post by JetForMe »
Sorry, I didn't mean generally what it's doing. I meant, very specifically, how is the AVR port_switch() doing what it does? I don't know where to find ABI documentation for AVR/GCC, so it's hard for me to understand specifically how it's performing the context switch. In particular around those registers r22/23 and r24/25.
Re: IAR AVR Port
When I wrote the AVR port the description of the used registers was on the AVRGCC web site documentation, I don't know the status now. You could also ask on the GCC mailing list eventually.
JetForMe
Re: IAR AVR Port
Post by JetForMe »
Okay.
BTW, what do you think about making an AVR section of the forum?
Re: IAR AVR Port
Usually I create a forum when there is at least a maintainer for the platform. AVR so far is not maintained.
JetForMe
Re: IAR AVR Port
Post by JetForMe »
Well, I'm sure trying to, but I'm having a hard time getting any traction.
I think I'm going to have to give up on ChibiOS for this project. I want to have it ready for Makerfaire May 18, and I've already wasted a three-day weekend with nothing to show in terms of actual functionality.
Re: IAR AVR Port
Sorry to hear that.
