Page 5 of 5
Re: DAC driver for the STM32
Posted: Sat Nov 16, 2013 9:30 pm
by alex0
Hello! :?:
I wanted to try the DAC driver for STM32F4xx.
First, I made a clone of the repository https://github.com/mobyfab/ChibiOS/tree/dac
Then, compile the example shown in the folder ChibiOS\testhal\STM32F4xx\DAC\
But it throws the following errors:
../../../os/hal/platforms/STM32/DACv1/dac_lld.h:258:3: error: unknown type name 'dacmode_t'
In file included from ../../../os/hal/include/hal.h:50:0,
from ../../../test/test.c:26:
../../../os/hal/include/dac.h:308:3: error: unknown type name 'DACConversionGroup'
../../../os/hal/include/dac.h:309:27: error: unknown type name 'dacsample_t'
../../../os/hal/include/dac.h:310:3: error: unknown type name 'DACConversionGroup'
../../../os/hal/include/dac.h:311:28: error: unknown type name 'dacsample_t'
../../../os/hal/include/dac.h:315:3: error: unknown type name 'DACConversionGroup'
../../../os/hal/include/dac.h:316:20: error: unknown type name 'dacsample_t'
make: *** [build/obj/test.o] Error 1
How well are the steps you took?
From what I see the problem is compatibility between files dac_lld.c/.h and dac.c/.h :oops:
Thank you!
Greetings!
Posted: Sun Nov 17, 2013 2:15 am
by beaming
You should have cloned the dac-new tree instead of just dac.
https://github.com/mobyfab/ChibiOS/tree/dac-new
Posted: Mon Nov 18, 2013 1:41 pm
by alex0
Thank you! :P
Posted: Mon Nov 18, 2013 3:48 pm
by mobyfab
Hey,
I Added demos for all STM32 devices now, F1 included.
I have fixed callbacks so it should work pretty well now.
Also there is now a dac branch forked from v3.0:
https://github.com/mobyfab/ChibiOS/tree/dac-3.0
Still very experimental.
Let me know if you have any issues.
Posted: Fri Mar 07, 2014 6:27 pm
I am integrating the driver in the 3.0 branch unchanged but there is some points that I think we should address:
1) Move the timers handling outside the driver, the GPT should be used for that (after doing few changes). the rationale is you may want to use any of the possible triggering sources for the DAC. This will also make the driver simpler.
2) Support for linked mode, it is required for stereo playback using a single DMA.
Posted: Sat Mar 08, 2014 5:25 pm
by mobyfab
Sounds good, I'll make the changes.
Posted: Thu Mar 20, 2014 12:17 am
by dismirlian
Hello, I've been testing the excellent DAC driver, and found some bugs:
1. Incorrect mask for CR (function dac_lld_start). When regshift is 16, the following lines behave incorrectly:
void dac_lld_start(DACDriver *dacp) {
    /* DAC configuration */
    dacp->dac->CR |= ( (dacp->dac->CR & ~STM32_DAC_CR_MASK) | \
      (STM32_DAC_CR_EN | STM32_DAC_CR_DMAEN | dacp->config->cr_flags) ) << regshift;
They could be changed to something like:
    dacp->dac->CR &=  ~(STM32_DAC_CR_MASK << regshift);
    dacp->dac->CR |= (STM32_DAC_CR_EN | STM32_DAC_CR_DMAEN | dacp->config->cr_flags) << regshift;
2. I think that dac_lld_stop should release the DMA stream, mirroring the ADC driver. Please note that I haven't analyzed the driver's state machine in detail... The modified code could look like this:
void dac_lld_stop(DACDriver *dacp) {
  /* If in ready state then disables the DAC clock.*/
  if (dacp->state == DAC_READY) {
   dmaStreamRelease(dacp->dma);
#if STM32_DAC_USE_CHN1
3. Maybe dac_lld_stop_conversion should disable the DMA stream, instead of releasing it:
void dac_lld_stop_conversion(DACDriver *dacp) {
  /* If in active state then disables the DAC.*/
  if (dacp->state == DAC_ACTIVE) {
    /* DMA disable.*/
    dmaStreamDisable(dacp->dma);
    dacp->state = DAC_READY;
4. The DAC driver causes the uC to hang sporadically. Disabling the timer before stopping the conversion solves the issue, and the uC doesn't hang any more, but my fix is rather dirty, because I had to move code from dac_lld_start to dac_lld_start_conversion. This is my "final" code:
#if STM32_DAC_USE_CHN1 || STM32_DAC_USE_CHN2 || STM32_DAC_USE_CHN3
    dacp->clock = STM32_TIMCLK1;
//    arr = (dacp->clock / dacp->config->frequency);
//    chDbgAssert((arr <= 0xFFFF),
//        "dac_lld_start(), #1", "invalid frequency");
    /* Timer configuration.*/
    dacp->tim->CR1  = 0;                        /* Initially stopped.   */
    dacp->tim->PSC  = 0;                        /* Prescaler value.     */
    dacp->tim->DIER = 0;
//    dacp->tim->ARR  = arr;
    dacp->tim->EGR  = TIM_EGR_UG;               /* Update event.        */
    dacp->tim->CR2  &= (uint16_t)~TIM_CR2_MMS;
    dacp->tim->CR2  |= (uint16_t)TIM_CR2_MMS_1; /* Enable TRGO updates. */
    //dacp->tim->CNT  = 0;                        /* Reset counter.       */
    //dacp->tim->SR   = 0;                        /* Clear pending IRQs.  */
    /* Update Event IRQ enabled. */
    /* Timer start.*/
    //dacp->tim->CR1  = TIM_CR1_CEN;
void dac_lld_start_conversion(DACDriver *dacp) {
  chDbgAssert(dacp->samples, "dac_lld_start_conversion(), #1",
    "dacp->samples is NULL pointer");
  dmaStreamSetMemory0(dacp->dma, dacp->samples);
  dmaStreamSetTransactionSize(dacp->dma, dacp->depth);
  dmaStreamSetMode(dacp->dma, dacp->dmamode | STM32_DMA_CR_EN |
  STM32_DMA_CR_CIRC);
  dacp->tim->ARR = (dacp->clock / dacp->config->frequency);
    /* Timer start.*/
   dacp->tim->CR1 = 0;
    /* DMA disable.*/
Diego
Posted: Thu Mar 20, 2014 8:54 am
Thanks for finding, I am doing changes to the DAC driver and will look in the above points too.
Posted: Tue Oct 28, 2014 2:51 am
by c2issy
I have started working on the dac driver recently to build a random waveform generator when I saw your post.
As a newbie to chibiOS, I tried to look at your code but it seems that the git links you provided have expired.
Could you kindly send me your implementation of the dac driver? I would be really grateful if you could help. Stuck by the problem for a long time.
I'm using STM32F4 discovery board and chibiOS RT right now.
Cheers,
CC
