SD-Card Insert/Remove Handlers
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Re: SD-Card Insert/Remove Handlers
Post by Tabulous »
so the panic msg is saying stack overflow, but is i said earlier if i increase the the thread static WORKING_AREA(waThread1, 128); from 128 (default value) upto 512, it then hits the _unhandled_exception
Tabulous
Post by Tabulous »
the unhandled_exception is hit when chThdSleepMilliseconds(1000); is called in the blinker thread
By examining the stack areas you can understand which stack is overflowing, if you use ChibiStudio then the ChibiOS debug view does that for you.
Tabulous
Post by Tabulous »
do i need to enable this as by default the ChibiOS/RT view as nothing in it all fields and tabs are empty
Tabulous
Post by Tabulous »
right declaring the varibles the are used by the f_open locally caused the _unhandled_exception
FIL file;
UINT wbytes;
FRESULT result;
char msgstr[40];
if i then increased WORKING area to 512 all is working.
The RT view is working now, that must have been down to the stack issues.
Tabulous
Post by Tabulous »
Now have a working USB-CDC and SD-Card Demo for STM3241G-EVAL board.
Giovanni - if you would like this demo for your repository let me know and i'll send it to you :-)
Thanks for teh help
If you could post a ready-to-go zip file in the contributions forum it would be great.
About the ChibiOS view, you need to hit the refresh button in the toolbar.
Jeroen3
Post by Jeroen3 »
Returning from
DWORD create_chain(FATFS* fs,   DWORD clst )
At the B instruction, seem to throw an hardfault in ff.c from fatfs R0.10b.
This gets called from f_stat, all other fatfs functionality seems ok.
Jeroen3
Post by Jeroen3 »
This is because a FILINFO structure is assumed to be "empty" when filled with 0. When filled with standard stackfill of 0x55 it will crash.
It was in reaction to mukululul a few pages back, not very on topic anymore.
Good to know anyway :)
