Page 5 of 12
Re: ST-Link V2 on Linux/OSX/Windows
Posted: Tue Dec 13, 2011 9:24 am
by Badger
The OSX package didn't work for me, looks like the Qt library isn't included with it:
Process:         qstlink2 [82023]
Path:            /Users/USER/Downloads/qstlink2.app/Contents/MacOS/qstlink2
Identifier:      com.yourcompany.qstlink2
Version:         ??? (???)
Code Type:       X86-64 (Native)
Parent Process:  launchd [312]
Date/Time:       2011-12-13 08:23:02.823 +0000
OS Version:      Mac OS X 10.7.2 (11C74)
Report Version:  9
Interval Since Last Report:          1036298 sec
Crashes Since Last Report:           41
Per-App Crashes Since Last Report:   1
Anonymous UUID:                      9ED4E3BB-ADE5-4EEF-9E6C-64790A28A774
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: /opt/local/lib/QtXml.framework/Versions/4/QtXml
  Referenced from: /Users/USER/Downloads/qstlink2.app/Contents/MacOS/qstlink2
  Reason: image not found
Binary Images:
       0x108566000 -        0x1085a8fef +com.yourcompany.qstlink2 (??? - ???) <4CB1375F-347C-33FE-89C8-AE7EB9E0FF58> /Users/USER/Downloads/qstlink2.app/Contents/MacOS/qstlink2
       0x1085ca000 -        0x1085ccfff +libusb-0.1.4.dylib (9.4.0 - compatibility 9.0.0) <5F02B138-D391-3751-8A9A-EEF18A7577B4> /usr/local/lib/libusb-0.1.4.dylib
    0x7fff68166000 -     0x7fff6819aac7  dyld (195.5 - ???) <4A6E2B28-C7A2-3528-ADB7-4076B9836041> /usr/lib/dyld
Model: MacBookPro5,5, BootROM MBP55.00AC.B03, 2 processors, Intel Core 2 Duo, 2.26 GHz, 4 GB, SMC 1.47f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x029E, 0x434D33583247534431303636202020202020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x029E, 0x434D33583247534431303636202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.100.98.75.18)
Bluetooth: Version 4.0.1f4, 2 service, 11 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: INTEL SSDSA2CW120G3, 120.03 GB
Serial ATA Device: ST9500420ASG, 500.11 GB
USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 2
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0x26500000 / 2
USB Device: STM32 STLink, 0x0483  (STMicroelectronics), 0x3748, 0x04100000 / 3
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0237, 0x04600000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x04500000 / 2
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8213, 0x06110000 / 3
Posted: Tue Dec 13, 2011 10:42 am
by noether
Tested on Debian Testing.
Compiled without any problems and it works fine for programming the Discovery with the M4F.
Posted: Tue Dec 13, 2011 11:58 am
by mobyfab
Badger wrote:The OSX package didn't work for me, looks like the Qt library isn't included with it:
Version:         ??? (???)
Report Version:  9
Crashed Thread:  0
Dyld Error Message:
Binary Images:
You have to install the libraries yourself, same on Linux.
Can you retry with the libraries ?
Thanks for testing. :)
Posted: Wed Dec 14, 2011 6:41 pm
by mobyfab
Latest update: (you asked for that Giovanni :) )
$ ./qstlink2 --help
Missing parameters, help below:
This application can be used through the GUI or via the command line. (CLI)
Command line usage:
qstlink2 [-hqvcwreV] [path]
-h, --help: shows this help
-q, --quiet: Quiet output (Nothing)
-v, --verbose: Verbose output (Debug)
-c,--cli: Enable command line mode
-w,--write: Enable write mode - Needs Path
-r,--read: Enable read mode - Needs Path
-e,--erase: Flash will be completely erased
-V, --verify: When used with write, the file will be verified against flash
-R, --reset: will reset the MCU
Example to write and verify the device:
qstlink2 -cwV /home/me/myfile.bin (you can also use relative paths like ./test.bin)
or
qstlink2 --cli --write --verify /home/me/myfile.bin
Please note that verify and reset are not implemented yet.
If you perform flash operations the device will be reseted anyways.
There is a Windows CLI version as well in the download area.
Posted: Sat Dec 17, 2011 9:54 pm
by JetForMe
I'm going to develop a board around the STM32F417x part family. I have a couple of the STM32F4-Discovery boards, and I'm glad to see you got it working under Linux. I'm using Mac OS X. Next week, I'll try to reproduce your efforts there. Thanks for the work!
Posted: Sun Mar 18, 2012 3:28 am
by carnecro
Anybody got qstlink2 running under Mac OSX? I try to make the project, ending with error 'missing usb.h', referenced from LibUsb.h. When I have a look at libusb project sources there is no usb.h. Any hint?
Posted: Thu Mar 22, 2012 2:59 am
by chrisjensen
carnecro wrote:Anybody got qstlink2 running under Mac OSX? I try to make the project, ending with error 'missing usb.h', referenced from LibUsb.h. When I have a look at libusb project sources there is no usb.h. Any hint?
I have used it before on my home computer, and just installed it on my portable (both are macs running 10.7.3). In order to make it work I installed qt-mac-opensource-4.8.0.dmg and qt-mac-opensource-4.8.0-debug-libs.dmg from
http://qt.nokia.com/downloads/qt-for-open-source-cpp-development-on-mac-os-x/
and then I installed the libUSB from a package 0.1.13beta (I couldn't get to the libusb site right now)
I was then able to load the qstlink program, and upload a precompiled binary. It seems to be working pretty well as far as I can tell. Let me know if you need me to link the libUSB file or send it to you just let me know.
-Chris
Posted: Sat Mar 24, 2012 10:29 pm
by carnecro
OK, seems the project uses the old and since 3 or 4 years no more supported libUSB version 0.1.x instead of the new 1.0.x. Note both releases are not compatible, 1.0.x is the fork and the project is active. I do not understand why new projects like this one does not take the official trunk, maybe the maintainer has any reason. There is another project mapping the 0.1.x calls to 1.0.x calls but it is terrible hack.
Posted: Mon Apr 02, 2012 8:23 am
by mobyfab
I had to use the old one since libusb-win32 uses this version, same for osx, the binary package is 0.1, plus it's more stable.
I don't think a port to 1.0 would be hard to do.
Posted: Thu Apr 05, 2012 10:41 am
by mobyfab
Why do you want 1.0?
