FDCAN with STM32H735
Edoardo1982
Has thanked: 10 times
Been thanked: 20 times
Re: FDCAN with STM32H735
Post by Edoardo1982 »
ych wrote:I encountered a limitation caused by the chThdSleepS(OSAL_MS2I(1)) delay in the FDCANv2 driver for STM32. A similar delay also exists in FDCANv1.
Due to this delay, I’m unable to send CAN FD frames faster than 1 kHz from a single thread, whereas my application requires a 2 kHz transmission rate.
Could someone explain the reason for this delay? Which STM32 chips are actually affected by the issue that this delay is intended to address?
I have checked errata and can't find any related issue.
In my case (STM32H723xx), I reduced the delay to chThdSleepS(OSAL_US2I(100)), and everything works flawlessly. From my perspective, it would be better to either completely remove the delay or keep it only for the specific chips that truly require it.
Hi, that delay was left over from a previous workaround.
I believe there's no issue in removing it.
Could you give me some feedback on how FDCAN works without that sleep?
Thanks
Edoardo
ych
Has thanked: 17 times
Been thanked: 11 times
Post by ych »
Edoardo1982 wrote:...
Hi Edoardo,
After a week in production without that sleep command, I haven't encountered any issues with FDCAN transmission.
It seems we can safely remove it.
The issue I encountered was due to a flaw in my code logic that accidentally relied on this hidden delay, rather than implementing a proper waiting mechanism.
Yurii.
Edoardo1982
Hi Edoardo,
Yurii.
Thank you for your feedback, I remove that sleep from the code right away.
Edoardo
ych
Post by ych »
Edoardo
Would it be possible to remove it as well from at least the latest stable version, [font=Courier New]stable_21.11.x[/font]?
Edoardo1982
Edoardo
Sure,
I'll do it in the next few days.
Edoardo
