alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
The peripheral is the same in F3 so it should be similar, the exact values have to be calculated, details are in the STM32 Reference Manual.
The STM32CubeMX application can compute the TIMINGR value for you. Within STM32CubeMX, create a H7 project, configure the clock tree, then the I2C port you want to use, and you can generate pdf and text rapport where TIMINGR is calculated as a 32 bits constant.
The tool can even generate init code, but alas, not for ChibiOS :-/
Alexandre
maciek
Post by maciek »
thanks for the answers, I've generated the project in STM32CubeMX, and the resulting "Timing" constant I got is 0x10707DBC. Does it make sense? I'll check if it works in my ChibiOS I2C project.
As far as could I determine, ADCs and SDIO/SDC seem to be not supported yet?
Correct, H7 support is not complete yet.
Small update.
I added a demo for the H7 ADC, the code compiles and runs but the result is not what I expect, the buffer contains zeros even if the DMA started and wrote data.
There must still be some stupid error in the driver.
The driver is working now, tested one-shot and continuous circular modes.
bluuu
Post by bluuu »
Thanks for update. Good job.
Any plans for SDMMC driver ?
bluuu
Post by bluuu »
bump
No immediate plans, partly because lack of HW.
maciek
Post by maciek »
which HW do you need? Would Nucleo H743ZI do the job?
https://os.mbed.com/platforms/ST-Nucleo-H743ZI/
and also an SD card board with SDIO interface, connected to Nucleo?
I think some of us would be happy to fund such a board as our contribution to Chibios on H7 controllers. Do you prefer a donation or a real board, already wired to the SD shield?
I have already that board, it doesn't have the SDMMC connector and I think that attaching one with floating wires would not work as expected. Some tried, should search topics in the forum about this.
