GDISP driver
Locked
Re: GDISP driver
Hello petr!
Thank you for trying out the GDISP driver. Sadly I couldn't compile it myself yet so I don't even know if I would have the same problem.
Feel free to attach your entire project folder, including source code, Makefile, all config files etc. as a zip file.
inmarket couldn't try out any of the code yet, so it is very likely that there is a bug in the font rendering.
Feel free to use the current implementation of the drivers to continue your work/project. One the halext stuff is done, you will be able to switch to it without loosing any features.
Badger
Re: GDISP driver
Post by Badger »
Hi Petr,
what orientation are you using? it is likely that the write order for sequential write is wrong. If inverted then try non-inverted and see if the problem persists.
Abhishek
Re: GDISP driver
Post by Abhishek »
I just got my S6D1121 code to compile.
Testing now.
Re: GDISP driver
Abhishek wrote:I just got my S6D1121 code to compile.
Can you tell me exactly step by step what you did? I wasn't able to compile, doing exactly what's described in the readme.
Did you replace glcd/glcd.h with halext/inc/glcd.h ?
Abhishek
Re: GDISP driver
Post by Abhishek »
The thing is, you don't have to use the GLCD makefile. You'll have to use the makefile provided in halext folder.
Abhishek
Re: GDISP driver
Post by Abhishek »
Hello petr,
which font are you using?
Abhishek
Re: GDISP driver
Post by Abhishek »
I too got garbage in text rendering, the driver works fine.
Abhishek
Re: GDISP driver
Post by Abhishek »
The new text rendering engine seems broken.
Re: GDISP driver
Fix it then :)
Abhishek
Re: GDISP driver
Post by Abhishek »
The code size is very less (only 9400 bytes, 8000 bytes by ChibiOS)
Looks like the font tables are getting optimized out.
Locked
