SDIO port to STM32F4x
barthess
Re: SDIO port to STM32F4x
Post by barthess »
Giovanni wrote:Do you have the embsys register plugin for Eclipse installed?
Thanks for hint. Looks very useful.
Giovanni wrote:I still have to update all the halconf.h and mcuconf.h in all the demos
What changes you mind? Probably it worth to create simple bash script for this job?
Hehe, the boring part is to make sure to add all the new settings to all configuration files and make sure those are all aligned. Probably there should be templates also for the mcuconf.h files.
A script is a good idea, the hard part is to make it retain the settings for the specific demo while updating.
Probably it would also be a good idea to check the OS version numbers from inside the configuration files in order to ensure those are aligned with the version in use. It is easily overlooked when updating and can create problems.
barthess
Post by barthess »
Hm... simple append of some strings to the end of files is trivial, but it anyway must be checked later by hand. Quick and dirty solution:
#/bin/sh
# $1 is first command line argument for script
echo $1
echo '/*
 * SDC driver system settings.
#define STM32_SDC_SDIO_DMA_STREAM           STM32_DMA_STREAM_ID(2, 3)
#define STM32_SDC_SDIO_DMA_PRIORITY         3
#define STM32_SDC_SDIO_IRQ_PRIORITY         9
#define STM32_SDC_SDIO_UNALIGNED_SUPPORT    TRUE' >> $1
save this to "testhal/STM32F4xx/update_mcuconf.sh". I think content of script is self descriptive.
than cd to "testhal/STM32F4xx" and call from command line (it works in Cygwin too)
find . -name 'mcuconf.h' -exec ./update_mcuconf.sh '{}' \;
probably after that you must call
find . -name 'mcuconf.h' -exec unix2dos '{}' \;
to fix new line symbols.
Insertion of code somewhere in middle of halconf.h needs special markers (something like /* end of HAL_USE */ )
Jacon
Has thanked: 50 times
Been thanked: 5 times
Post by Jacon »
Giovanni wrote:Do you have the embsys register plugin for Eclipse installed? it allows to inspect HW registers for many MCUs (not sure if SDIO is included).
https://sourceforge.net/projects/embsysregview/
It is often very useful.
But not for us STM32-F4's due lack of proper register xml files ;)
I finally tested the new driver on the F1xx, apparently everything is OK. I am not sure about the use of critical zones (inherited from the old driver), I am going to review those.
I also wish to add some kind of channels-like generic interface in order to make the MMC_SPI and SDC drivers compatible at interface level. This will make integration with FS simpler.
barthess
Post by barthess »
Did you test it on F4x? On my board OS locks on dmaWaitCompletion(sdcp->dma) function (sdc_lld.c line 181).
I don't have HW to test it on the F4, the board I have is wired to use SPI.
dmaWaitCompletion() should wait the end of the operation and then disable the channel.
There are two possible possible causes if it stops there:
1) The NDTR register never counts down to zero for some reason.
2) The STM32_DMA_CR_EN bit does not go to zero after clearing it.
#define dmaStreamClearInterrupt(dmastp) {                                   \
  *(dmastp)->ifcr = STM32_DMA_ISR_MASK << (dmastp)->ishift;                 \
#define dmaStreamDisable(dmastp) {                                          \
  (dmastp)->stream->CR &= ~STM32_DMA_CR_EN;                                 \
  while (((dmastp)->stream->CR & STM32_DMA_CR_EN) != 0)                     \
  dmaStreamClearInterrupt(dmastp);                                          \
#define dmaWaitCompletion(dmastp) {                                         \
  while ((dmastp)->stream->NDTR > 0)                                        \
  dmaStreamDisable(dmastp);                                                 \
Both would be very strange.
barthess
Post by barthess »
I remember. Checking content of NDTR register is not usable for SDIO because it always set to maximum value because peripheral is flow controller. Probably we must use #ifdef clause for F4x/F2x with my old code checking the end of transaction.
barthess
Post by barthess »
Fixed in rev.4123
I see, thanks, the only problem I have with that is not with the code itself, but with the abstraction that is not sufficient to hide that detail away. Not a real problem anyway because F1 and F2/F4 already have separate code paths in several other places.
