MIPS32 port
Re: MIPS32 port
I have a kind of good news: finally I defeated xc32. From now on it's possible to build and successfully run chibi built by this beast =).
Also I added generation of iHex for when built with GCC.
I've pushed my changes into the repository.
Now I'm going to start on some peripherals.
Also I would like to add possibility to run some code from RAM. It could be interesting for performance boost. Especially some hot paths like ISRs and scheduler.
best regards,
-- dmytro
best regards,
-- dmytro
Re: MIPS32 port
There is still an issue with the .hex generated. When uploaded via pic32prog (lin) or flashed w/ pickit2 (win) it gets flashed, but it does not work.
The only way to get it flashed here is import/export via mplab and then flashed with pickit2.
Also getting this warning:
Linking build/ch.elf
/usr/local/pic32-tools/bin/../lib/gcc/pic32mx/4.5.1/../../../../pic32mx/bin/ld:ld/mips_pic32mx795f512l.lds:148: warning: memory region `exception_mem' not declared
/usr/local/pic32-tools/bin/../lib/gcc/pic32mx/4.5.1/../../../../pic32mx/bin/ld: Warning: exception_mem memory region not defined, using default range: 0x9fc01000 .. 0x9fc01fff
Creating build/ch.srec
Creating build/ch.hex
Re: MIPS32 port
The generated hex:
and the hex imported/exported via mplab (works):
It seems the mplab does correct some anomalies within the hex (ie. line 10D13, and from 10D21 up)..
:10D12000A0B4009DD0D0009DE0B3009D9CC2009DA6
:0CD13000D0B3009D0000000000000000D3
:10D14000000000A0000000A0000000000C0000A0F3
:10D150000C0000A0140000A0140000A000000000BB
:10D1600000000000240000A0240000A00000000037
:10D1700000000000681500A07C1500A0681500A044
:10D18000681500A0440000A0440000A000000000BA
:10D19000500000A0500000A0050000005C0000A0AE
:10D1A000600000A0000000009001000000000000EE
:10D1B000700000A0700000A004000000F81600A09D
:10D1C000FC1600A0F81600A0F81600A01085009D1F
:10D1D00000000000940000A0940000A000000000E7
:10D1E000681500A06C1500A0681500A0681500A0C7
:10D1F0001085009D000000005CCB009D00A6009DF6
:10D200004CCB009DD0A5009D000000000000000058
:020000041FC01B
:1000000002001A2400809A4000688040006080400E
:1000100001608040009D083CB4030825FFFF093CB7and the hex imported/exported via mplab (works):
:10D13000D0B3009D0000000000000000FFFFFFFFD3
:10D21000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
:10D22000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0EIt seems the mplab does correct some anomalies within the hex (ie. line 10D13, and from 10D21 up)..
Re: MIPS32 port
On the left there is .hex exported from pickit2 tool (preprocessed with imp/exp via mplab, hex which works) and right is the original .hex exported from pickit2.
The difference is depicted below:
PS: Solved??
When I load the "original hex" (bad one) into pickit2 I see DEVCFG0 as FF0A.
When I change manually the DEVCFG0 to FF0B (as it should be in "the good one") the hex WORKS.
So the bit0 of the DEVCFG0 is doing the trick. BTW FF0A means "DEBUG enabled".
PS: Solved??
Re: MIPS32 port
I wonder whether that's a pb of pic32prog or pickit2 in general.
Did you try to flash the target with mplabx and 'broken' hex?
Re: MIPS32 port
I am using pic32MX795F512H (64pin), so maybe there is a difference against pic32MX795F512L (100pin)
in processing of that bit0.
I cannot flash from mplabx as it does not support pickit2 for that mcu.
PS1: I've built it with
USE_OPT += -D__32MX795F512H__
and the picki2's ch.hex still shows F00A (bad) instead of F00B. So it seems the DEBUG config bits shall be set in the source.
Re: MIPS32 port
Yes, this creates the ch.hex which now works with pickit2 (win):
There is still an issue with it, however, as the pic32prog (via hid bootloader, lin) flashes "boot mem" as well (it shall not) and the code does not work..
PIC32MX_DEVCFG0(
DEVCFG0_ICESEL_CH2 // Use PGC2/PGD2
| DEVCFG0_DEBUG_DISABLED // Disable DEBUG by Pito
);There is still an issue with it, however, as the pic32prog (via hid bootloader, lin) flashes "boot mem" as well (it shall not) and the code does not work..
pito@ubuntu:~/chibios/ChibiOS-mips-pic32mx/demos/MIPS-PIC32MX795F512L-PIC32-MAXI-WEB/build$ sudo /home/pito/pic32prog/pic32prog ch.hex
Programmer for Microchip PIC32 microcontrollers, Version 1.74
Copyright: (C) 2011-2012 Serge Vakulenko
Adapter: HID Bootloader
Program area: 1d000000-1d07ffff
Processor: Bootloader
Flash memory: 512 kbytes
Data: 54124 bytes
Erase: done
Program flash: ###################################################### done
Program boot: # done
Verify flash: ###################################################### done
Verify boot: done
Rate: 7346 bytes per second
Re: MIPS32 port
Thanks for the analysis. I believe that by default it won't be harmful to disable DEBUG. I pushed this change.
