[DEV] RP2040 support
hanya
Re: [DEV] RP2040 support
Post by hanya »
Thank you for your response. I will try to choose collect mode for set address.
And I found the following description about the SET_ADDRESS request in the pico-sdk.
From pico-sdk, dev_lowlevel.c
 * @brief Handles a SET_ADDR request from the host. The actual setting of the device address in
 * hardware is done in ep0_in_handler. This is because we have to acknowledge the request first
 * as a device with address zero.
 * @param pkt, the setup packet from the host.
void usb_set_device_address(volatile struct usb_setup_packet *pkt) {
It looks I could choose set of USB_SET_ADDRESS_ACK_SW and USB_LATE_SET_ADDRESS.
But I have trouble on the IN transfer after the SET_ADDRESS request. It would not finished, so set_address callback would not called.
xyz
Post by xyz »
hanya wrote:Thank you for your response. I will try to choose collect mode for set address.
Hi hanya, I've sent you a PR on github which fixes this and some other issues, please check it at https://github.com/hanya/ChibiOS-Contrib/pull/1
xyz
Post by xyz »
There's also a bug in chibios gpio implementation in os/hal/ports/RP/LLD/GPIOv1/hal_pal_lld.h
diff --git a/os/hal/ports/RP/LLD/GPIOv1/hal_pal_lld.h b/os/hal/ports/RP/LLD/GPIOv1/hal_pal_lld.h
index 34b88855d..dae4079f7 100644
--- a/os/hal/ports/RP/LLD/GPIOv1/hal_pal_lld.h
+++ b/os/hal/ports/RP/LLD/GPIOv1/hal_pal_lld.h
@@ -389,7 +389,7 @@ __STATIC_INLINE void __pal_lld_pad_set_mode(ioportid_t port,
   ctrlbits = (mode & 0x007FFFFFU) >> 0U;
   oebits   = (mode & 0x00800000U) >> 23U;
-  padbits  = (mode & 0xF0000000U) >> 24U;
+  padbits  = (mode & 0xFF000000U) >> 24U;
   /* Setting up GPIO direction first.*/
   if (oebits != 0U) {
Currently it does "mode & 0xF0000000U" which ends up ignoring low 4 of gpio config bits, e.g. PAL_RP_PAD_PUE, so pull-up never ends up enabled.
FXCoder
Has thanked: 188 times
Been thanked: 134 times
Post by FXCoder »
Fixed in trunk.
hanya
Post by hanya »
I have updated code a bit. Now USB state can be reached to configured state.
The lsusb command shows correct information about its descriptors.
HID test code seems working but there are some data error shown, maybe PID problem.
The shell through CDC does not start yet.
hanya
Post by hanya »
xyz wrote:Hi hanya, I've sent you a PR on github which fixes this and some other issues, please check it at https://github.com/hanya/ChibiOS-Contrib/pull/1
Hi xyz, thanks for your PR. I have fixed some of them before I notice your PR. But I did not noticed about wrong setting of buffer offset.
I added shell example. After few fix, ChibiOS/RT Shell is working well now.
findeluxe
Post by findeluxe »
Hi, thanks for this port, it looks very promising. I've noticed that os/hal/ports/RP/LLD/TIMERv1/driver.mk already refers to hal_gpt_lld.c (for GPT support), but it seems that this is either not implemented yet - or maybe you forgot to commit those files? :-) I tried to use the pico-sdk library for GPT-like functionality (same as I did for I2C, which more or less works), but frankly, it's a giant mess trying to mix DMA/IRQ usage from both ChibiOS and pico-sdk...
GPT is in preparation so not finished.
In general Pico-SDK is written like it is the only SW in the system, it does not play well with 3rd parties libraries, lots of name conflicts and assumptions in there. I hoped to "use" it but I right now I am just looking at it as reference code.
Clock initialization is an exception, we are using it as-is, eventually we will remove the dependency on that too.
Any idea about how to submit feedback? they could be interested in the integration problems we are facing.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
Giovanni wrote:Any idea about how to submit feedback? they could be interested in the integration problems we are facing.
Submit an "issue" at https://github.com/raspberrypi/pico-sdk is your best bet.
Suggest you are cautious - in the beginning the RPT got some fairly fierce criticism, mostly from experienced software developers, about some of their implementation choices. (What they have done is great for raw beginners, and the chip datasheets put many larger companies to shame; but I'm not sure they really considered third parties adding the RP2040 to other platforms).
If you want to provoke a more public reaction (most users don't look at Github, as far as I can see), another forum post at https://www.raspberrypi.org/forums/viewforum.php?f=145.
Incidentally, they are working on a FreeRTOS port, which may also give some hints:
https://github.com/PicoCPP/RPI-pico-FreeRTOS
https://github.com/kilograham/FreeRTOS- ... GCC/RP2040
https://github.com/kilograham/FreeRTOS/ ... %2B_RP2040
Don't think its complete yet.
hanya
Post by hanya »
Please add structure definition for PWM register.
diff --git a/os/common/ext/RP/RP2040/rp2040.h b/os/common/ext/RP/RP2040/rp2040.h
index 01c911d..7423d88 100644
--- a/os/common/ext/RP/RP2040/rp2040.h
+++ b/os/common/ext/RP/RP2040/rp2040.h
@@ -896,6 +896,67 @@ struct {
   } CLR;
 } ADC_TypeDef;
+typedef struct {
+  struct {
+    __IO uint32_t       CSR;
+    __IO uint32_t       DIV;
+    __IO uint32_t       CTR;
+    __IO uint32_t       CC;
+    __IO uint32_t       TOP;
+  } CH[8];
+  __IO uint32_t         EN;
+  __IO uint32_t         INTR;
+  __IO uint32_t         INTE;
+  __IO uint32_t         INTF;
+  __I  uint32_t         INTS;
+  __I  uint32_t         resvdpwm[979];
+  struct {
+    struct {
+      __IO uint32_t     CC;
+    } CH[8];
+    __IO uint32_t       EN;
+  } XOR;
+  struct {
+    struct {
+      __IO uint32_t     CC;
+    } CH[8];
+    __IO uint32_t       EN;
+  } SET;
+  struct {
+    struct {
+      __IO uint32_t     CC;
+    } CH[8];
+    __IO uint32_t       EN;
+  } CLR;
+} PWM_TypeDef;
 typedef struct {
   __IO uint32_t         DEVADDRCTRL;
   __IO uint32_t         INTEPADDRCTRL[15]; /* USB_HOST_INTERRUPT_ENDPOINTS */
@@ -2476,6 +2537,190 @@ typedef struct {
 #define I2C_IC_COMP_PARAM_1_APB_DATA_WIDTH_Msk           (3U << I2C_IC_COMP_PARAM_1_APB_DATA_WIDTH_Pos)
 #define I2C_IC_COMP_PARAM_1_APB_DATA_WIDTH               I2C_IC_COMP_PARAM_1_APB_DATA_WIDTH_Msk
+ * @name    PWM bits definitions
+#define PWM_CSR_PH_ADV_Pos                               7U
+#define PWM_CSR_PH_ADV_Msk                               (1U << PWM_CSR_PH_ADV_Pos)
+#define PWM_CSR_PH_ADV                                   PWM_CSR_PH_ADV_Msk
+#define PWM_CSR_PH_RET_Pos                               6U
+#define PWM_CSR_PH_RET_Msk                               (1U << PWM_CSR_PH_RET_Pos)
+#define PWM_CSR_PH_RET                                   PWM_CSR_PH_RET_Msk
+#define PWM_CSR_DIVMODE_Pos                              4U
+#define PWM_CSR_DIVMODE_Msk                              (0x3U << PWM_CSR_DIVMODE_Pos)
+#define PWM_CSR_DIVMODE(n)                               ((n) << PWM_CSR_DIVMODE_Pos)
+#define PWM_CSR_B_INV_Pos                                3U
+#define PWM_CSR_B_INV_Msk                                (1U << PWM_CSR_B_INV_Pos)
+#define PWM_CSR_B_INV                                    PWM_CSR_B_INV_Msk
+#define PWM_CSR_A_INV_Pos                                2U
+#define PWM_CSR_A_INV_Msk                                (1U << PWM_CSR_A_INV_Pos)
+#define PWM_CSR_A_INV                                    PWM_CSR_A_INV_Msk
+#define PWM_CSR_PH_CORRECT_Pos                           1U
+#define PWM_CSR_PH_CORRECT_Msk                           (1U << PWM_CSR_PH_CORRECT_Pos)
+#define PWM_CSR_PH_CORRECT                               PWM_CSR_PH_CORRECT_Msk
+#define PWM_CSR_EN_Pos                                   0U
+#define PWM_CSR_EN_Msk                                   (1U << PWM_CSR_EN_Pos)
+#define PWM_CSR_EN                                       PWM_CSR_EN_Msk
+#define PWM_CSR_PH_CORRECT_PHASE_CORRECT_MODULATION      (1U << PWM_CSR_PH_CORRECT_Pos)
+#define PWM_CSR_PH_CORRECT_TRAILING_EDGE                 (0U << PWM_CSR_PH_CORRECT_Pos)
+#define PWM_CSR_DIVMODE_FREE                             PWM_CSR_DIVMODE(0U)
+#define PWM_CSR_DIVMODE_GATED                            PWM_CSR_DIVMODE(1U)
+#define PWM_CSR_DIVMODE_RISING_EDGE                      PWM_CSR_DIVMODE(2U)
+#define PWM_CSR_DIVMODE_FALING_EDGE                      PWM_CSR_DIVMODE(3U)
+#define PWM_DIV_INT_Pos                                  4U
+#define PWM_DIV_INT_Msk                                  (0xFFU << PWM_DIV_INT_Pos)
+#define PWM_DIV_INT                                      PWM_DIV_INT_Msk
+#define PWM_DIV_FRAC_Pos                                 0U
+#define PWM_DIV_FRAC_Msk                                 (0xFU << PWM_DIV_FRAC_Pos)
+#define PWM_DIV_FRAC                                     PWM_DIV_FRAC_Msk
+#define PWM_CTR_COUNTER_Pos                              0U
+#define PWM_CTR_COUNTER_Msk                              (0xFFFFU << PWM_CTR_COUNTER_Pos)
+#define PWM_CTR_COUNTER                                  PWM_CTR_COUNTER_Msk
+#define PWM_CC_B_Pos                                     16U
+#define PWM_CC_B_Msk                                     (0xFFFFU << PWM_CC_B_Pos)
+#define PWM_CC_B                                         PWM_CC_B_Msk
+#define PWM_CC_A_Pos                                     0U
+#define PWM_CC_A_Msk                                     (0xFFFFU << PWM_CC_A_Pos)
+#define PWM_CC_A                                         PWM_CC_A_Msk
+#define PWM_TOP_VALUE_Pos                                0U
+#define PWM_TOP_VALUE_Msk                                (0xFFFFU << PWM_TOP_VALUE_Pos)
+#define PWM_TOP_VALUE                                    PWM_TOP_VALUE_Msk
+#define PWM_EN_CH7_Pos                                   7U
+#define PWM_EN_CH7_Msk                                   (1U << PWM_EN_CH7_Pos)
+#define PWM_EN_CH7                                       PWM_EN_CH7_Msk
+#define PWM_EN_CH6_Pos                                   6U
+#define PWM_EN_CH6_Msk                                   (1U << PWM_EN_CH6_Pos)
+#define PWM_EN_CH6                                       PWM_EN_CH6_Msk
+#define PWM_EN_CH5_Pos                                   5U
+#define PWM_EN_CH5_Msk                                   (1U << PWM_EN_CH5_Pos)
+#define PWM_EN_CH5                                       PWM_EN_CH5_Msk
+#define PWM_EN_CH4_Pos                                   4U
+#define PWM_EN_CH4_Msk                                   (1U << PWM_EN_CH4_Pos)
+#define PWM_EN_CH4                                       PWM_EN_CH4_Msk
+#define PWM_EN_CH3_Pos                                   3U
+#define PWM_EN_CH3_Msk                                   (1U << PWM_EN_CH3_Pos)
+#define PWM_EN_CH3                                       PWM_EN_CH3_Msk
+#define PWM_EN_CH2_Pos                                   2U
+#define PWM_EN_CH2_Msk                                   (1U << PWM_EN_CH2_Pos)
+#define PWM_EN_CH2                                       PWM_EN_CH2_Msk
+#define PWM_EN_CH1_Pos                                   1U
+#define PWM_EN_CH1_Msk                                   (1U << PWM_EN_CH1_Pos)
+#define PWM_EN_CH1                                       PWM_EN_CH1_Msk
+#define PWM_EN_CH0_Pos                                   0U
+#define PWM_EN_CH0_Msk                                   (1U << PWM_EN_CH0_Pos)
+#define PWM_EN_CH0                                       PWM_EN_CH0_Msk
+#define PWM_INTR_CH7_Pos                                 7U
+#define PWM_INTR_CH7_Msk                                 (1U << PWM_INTR_CH7_Pos)
+#define PWM_INTR_CH7                                     PWM_INTR_CH7_Msk
+#define PWM_INTR_CH6_Pos                                 6U
+#define PWM_INTR_CH6_Msk                                 (1U << PWM_INTR_CH6_Pos)
+#define PWM_INTR_CH6                                     PWM_INTR_CH6_Msk
+#define PWM_INTR_CH5_Pos                                 5U
+#define PWM_INTR_CH5_Msk                                 (1U << PWM_INTR_CH5_Pos)
+#define PWM_INTR_CH5                                     PWM_INTR_CH5_Msk
+#define PWM_INTR_CH4_Pos                                 4U
+#define PWM_INTR_CH4_Msk                                 (1U << PWM_INTR_CH4_Pos)
+#define PWM_INTR_CH4                                     PWM_INTR_CH4_Msk
+#define PWM_INTR_CH3_Pos                                 3U
+#define PWM_INTR_CH3_Msk                                 (1U << PWM_INTR_CH3_Pos)
+#define PWM_INTR_CH3                                     PWM_INTR_CH3_Msk
+#define PWM_INTR_CH2_Pos                                 2U
+#define PWM_INTR_CH2_Msk                                 (1U << PWM_INTR_CH2_Pos)
+#define PWM_INTR_CH2                                     PWM_INTR_CH2_Msk
+#define PWM_INTR_CH1_Pos                                 1U
+#define PWM_INTR_CH1_Msk                                 (1U << PWM_INTR_CH1_Pos)
+#define PWM_INTR_CH1                                     PWM_INTR_CH1_Msk
+#define PWM_INTR_CH0_Pos                                 0U
+#define PWM_INTR_CH0_Msk                                 (1U << PWM_INTR_CH0_Pos)
+#define PWM_INTR_CH0                                     PWM_INTR_CH0_Msk
+#define PWM_INTR_CH(n)                                   (1U << n)
+#define PWM_INTE_CH7_Pos                                 7U
+#define PWM_INTE_CH7_Msk                                 (1U << PWM_INTE_CH7_Pos)
+#define PWM_INTE_CH7                                     PWM_INTE_CH7_Msk
+#define PWM_INTE_CH6_Pos                                 6U
+#define PWM_INTE_CH6_Msk                                 (1U << PWM_INTE_CH6_Pos)
+#define PWM_INTE_CH6                                     PWM_INTE_CH6_Msk
+#define PWM_INTE_CH5_Pos                                 5U
+#define PWM_INTE_CH5_Msk                                 (1U << PWM_INTE_CH5_Pos)
+#define PWM_INTE_CH5                                     PWM_INTE_CH5_Msk
+#define PWM_INTE_CH4_Pos                                 4U
+#define PWM_INTE_CH4_Msk                                 (1U << PWM_INTE_CH4_Pos)
+#define PWM_INTE_CH4                                     PWM_INTE_CH4_Msk
+#define PWM_INTE_CH3_Pos                                 3U
+#define PWM_INTE_CH3_Msk                                 (1U << PWM_INTE_CH3_Pos)
+#define PWM_INTE_CH3                                     PWM_INTE_CH3_Msk
+#define PWM_INTE_CH2_Pos                                 2U
+#define PWM_INTE_CH2_Msk                                 (1U << PWM_INTE_CH2_Pos)
+#define PWM_INTE_CH2                                     PWM_INTE_CH2_Msk
+#define PWM_INTE_CH1_Pos                                 1U
+#define PWM_INTE_CH1_Msk                                 (1U << PWM_INTE_CH1_Pos)
+#define PWM_INTE_CH1                                     PWM_INTE_CH1_Msk
+#define PWM_INTE_CH0_Pos                                 0U
+#define PWM_INTE_CH0_Msk                                 (1U << PWM_INTE_CH0_Pos)
+#define PWM_INTE_CH0                                     PWM_INTE_CH0_Msk
+#define PWM_INTE_CH(n)                                   (1U << n)
+#define PWM_INTF_CH7_Pos                                 7U
+#define PWM_INTF_CH7_Msk                                 (1U << PWM_INTF_CH7_Pos)
+#define PWM_INTF_CH7                                     PWM_INTF_CH7_Msk
+#define PWM_INTF_CH6_Pos                                 6U
+#define PWM_INTF_CH6_Msk                                 (1U << PWM_INTF_CH6_Pos)
+#define PWM_INTF_CH6                                     PWM_INTF_CH6_Msk
+#define PWM_INTF_CH5_Pos                                 5U
+#define PWM_INTF_CH5_Msk                                 (1U << PWM_INTF_CH5_Pos)
+#define PWM_INTF_CH5                                     PWM_INTF_CH5_Msk
+#define PWM_INTF_CH4_Pos                                 4U
+#define PWM_INTF_CH4_Msk                                 (1U << PWM_INTF_CH4_Pos)
+#define PWM_INTF_CH4                                     PWM_INTF_CH4_Msk
+#define PWM_INTF_CH3_Pos                                 3U
+#define PWM_INTF_CH3_Msk                                 (1U << PWM_INTF_CH3_Pos)
+#define PWM_INTF_CH3                                     PWM_INTF_CH3_Msk
+#define PWM_INTF_CH2_Pos                                 2U
+#define PWM_INTF_CH2_Msk                                 (1U << PWM_INTF_CH2_Pos)
+#define PWM_INTF_CH2                                     PWM_INTF_CH2_Msk
+#define PWM_INTF_CH1_Pos                                 1U
+#define PWM_INTF_CH1_Msk                                 (1U << PWM_INTF_CH1_Pos)
+#define PWM_INTF_CH1                                     PWM_INTF_CH1_Msk
+#define PWM_INTF_CH0_Pos                                 0U
+#define PWM_INTF_CH0_Msk                                 (1U << PWM_INTF_CH0_Pos)
+#define PWM_INTF_CH0                                     PWM_INTF_CH0_Msk
+#define PWM_INTF_CH(n)                                   (1U << n)
+#define PWM_INTS_CH7_Pos                                 7U
+#define PWM_INTS_CH7_Msk                                 (1U << PWM_INTS_CH7_Pos)
+#define PWM_INTS_CH7                                     PWM_INTS_CH7_Msk
+#define PWM_INTS_CH6_Pos                                 6U
+#define PWM_INTS_CH6_Msk                                 (1U << PWM_INTS_CH6_Pos)
+#define PWM_INTS_CH6                                     PWM_INTS_CH6_Msk
+#define PWM_INTS_CH5_Pos                                 5U
+#define PWM_INTS_CH5_Msk                                 (1U << PWM_INTS_CH5_Pos)
+#define PWM_INTS_CH5                                     PWM_INTS_CH5_Msk
+#define PWM_INTS_CH4_Pos                                 4U
+#define PWM_INTS_CH4_Msk                                 (1U << PWM_INTS_CH4_Pos)
+#define PWM_INTS_CH4                                     PWM_INTS_CH4_Msk
+#define PWM_INTS_CH3_Pos                                 3U
+#define PWM_INTS_CH3_Msk                                 (1U << PWM_INTS_CH3_Pos)
+#define PWM_INTS_CH3                                     PWM_INTS_CH3_Msk
+#define PWM_INTS_CH2_Pos                                 2U
+#define PWM_INTS_CH2_Msk                                 (1U << PWM_INTS_CH2_Pos)
+#define PWM_INTS_CH2                                     PWM_INTS_CH2_Msk
+#define PWM_INTS_CH1_Pos                                 1U
+#define PWM_INTS_CH1_Msk                                 (1U << PWM_INTS_CH1_Pos)
+#define PWM_INTS_CH1                                     PWM_INTS_CH1_Msk
+#define PWM_INTS_CH0_Pos                                 0U
+#define PWM_INTS_CH0_Msk                                 (1U << PWM_INTS_CH0_Pos)
+#define PWM_INTS_CH0                                     PWM_INTS_CH0_Msk
+#define PWM_INTS_CH(n)                                   (1U << n)
 #ifdef __cplusplus
 extern "C" {
