Ethernet is working in trunk for me, please let me know.
What warnings exactly? I am not seeing those.
[DEV] STM32H7xx support (new)
mikeprotts
- Has thanked: 19 times
- Been thanked: 31 times
Re: [DEV] STM32H7xx support (new)
The warnings are unrelated to the Ethernet code, my project includes use of SPI and it's related to changes between 20.6 and 20.11 HAL version. I need to update my SPI code to use the current HAL to rule out the potential for some conflict or memory overwrite. Once I've fixed my SPI code I'll try the Ethernet again.
Look in the SPI configuration structure, there are 2 new fields, set them to false and NULL.
mikeprotts
Those extra fields did the trick thanks, no more warnings.
I suspect the a change in the NOCACHE areas might be an issue, it'll probably be next week before I have time to look at this. It would probably be better if I use a simpler build that just uses Ethernet and not much else.
Mike
Mike
mikeprotts
I've fixed my problem - I needed to match the MPU initialisation changes.
It seems to be working well now and good for me to be running with the latest code.
