Page 10 of 10
Re: [DEV] STM32H7xx support (new)
Posted: Fri Nov 11, 2022 10:43 am
Ethernet is working in trunk for me, please let me know.
What warnings exactly? I am not seeing those.
Posted: Wed Nov 16, 2022 5:26 pm
by mikeprotts
The warnings are unrelated to the Ethernet code, my project includes use of SPI and it's related to changes between 20.6 and 20.11 HAL version. I need to update my SPI code to use the current HAL to rule out the potential for some conflict or memory overwrite. Once I've fixed my SPI code I'll try the Ethernet again.
Posted: Wed Nov 16, 2022 8:52 pm
Look in the SPI configuration structure, there are 2 new fields, set them to false and NULL.
Posted: Thu Nov 17, 2022 1:19 pm
by mikeprotts
Those extra fields did the trick thanks, no more warnings.
I suspect the a change in the NOCACHE areas might be an issue, it'll probably be next week before I have time to look at this. It would probably be better if I use a simpler build that just uses Ethernet and not much else.
Mike
Posted: Wed Nov 23, 2022 5:15 pm
by mikeprotts
I've fixed my problem - I needed to match the MPU initialisation changes.
It seems to be working well now and good for me to be running with the latest code.
