Page 10 of 13
Re: MIPS32 port
Posted: Fri Mar 15, 2013 11:47 pm
by pito
Probably in Q3 we will get a new PIC32MZ series - up to 2MB flash, 512kB ram, 200MHz clock, mips14k core, etc. Maybe an improvement over the old PIC32MX
Re: MIPS32 port
Posted: Sat Mar 23, 2013 3:30 pm
by Dmytro
No news for some time but it does not mean that the project is dead.
Since last time the port gained:
Chibios:
* HAL DMA driver(HAL interface, LLD template, unit tests)
* chprintf: support of autoinsertion of '\r'(compile-time switch)
* chprintf: chvprintf variant
MIPS port:
* execution of the constructors before the call to main()
PIC32 port:
* EXT LLD(used state change feature of the pin, EXTx interrupts are out of scope)
* DMA LLD
* DMA support in SPI driver
* misc fixes
What's next? I suppose I'll implement timers and RTC LLDs. Any feedback is very welcome!
Re: MIPS32 port
Posted: Mon Apr 01, 2013 3:06 am
by Dmytro
I did some benchmarks w/ release build of pic32mx demo. Clearly this thing beats ARM even the freq of pic32 is slightly higher in some cases. Even in comparison with STM32F407@168MHz it's clear that mips architecture is not that bad...
Re: MIPS32 port
Posted: Mon Apr 01, 2013 3:43 am
by Tectu
Dear god... you're doing a very well job, respect!
May I drop a
twitter line about your benchmarks?
Also, why is there an -O2 optimization flag for the PIC but not for the others?
Re: MIPS32 port
Posted: Mon Apr 01, 2013 10:34 am
by Dmytro
Hi Tectu, it's -O2 for the others too. I took the numbers from
http://chibios.org/dokuwiki/doku.php?id=chibios:metrics#latest_test_reports.
Sure you can drop a tweet =)
Re: MIPS32 port
Posted: Sun Apr 14, 2013 1:04 am
by Dmytro
Few updates in PIC32MX port:
Chibios:
* HAL RTC: extend API to support configuration settings
MIPS port:
* RTC LLD
* ADC LLD
* GFX LCD and touch panel integration(LLD headers submitted to GFX repo as well)
* minor non-critical fixes
* merge with mainline(mabl's repo)
Re: MIPS32 port
Posted: Sun Apr 14, 2013 1:19 am
by Dmytro
I'm kindly raising the question about mip32 port inclusion into the mainline.
The port is almost complete. Missing LLDs I'm going to develop on demand(ethernet, PWM) but some of them I just can not test physically at this moment(like CAN).
IMHO pic32mx port enters maintenance phase.
What do you say?
Re: MIPS32 port
Posted: Sun Apr 14, 2013 7:28 am
I am just doing bug fixing because I want to finalize a 2.6.0 release, it is way overdue, we may merge the code afterward.
BTW, if the CAN peripheral has a loopback mode you can test it just like I do for the STM32, see the demos.
Re: MIPS32 port
Posted: Tue Apr 16, 2013 7:42 pm
by etmatrix
Dmytro wrote:Hi,
Hi Dmytro,
you got these benchmarks with this compiler
http://developer.mips.com/tools/compile ... toolchain/. Is it correct?
I tried with XC32 PRO and CodeSourcery and I got no good results. They was worst, with big distance. I don't remember exactly all differences, but were not good.
I will try to recompile the toolchain for my linux box X86 and I will try again the benchmarks.
Re: MIPS32 port
Posted: Tue Apr 16, 2013 9:21 pm
by Dmytro
Hi etmatrix,
I'm using prebuilt toolchain from mips.com(mips-sde-elf-gcc (GCC) 4.4.6) but there should not be any difference between native build of the toolchain and binary delivery.
I noticed some performance regression with gcc 4.6(or 4.7 don't remember exactly) so pay attention there.
Be careful when benchmarking the demo in mips port as it has all debug/development stuff enabled. Check for CH_DBG_* in chconf.h. Other demos do not include these checks.
Also take into account that the demo is quite big and full of timers, events, threads that may impact the benchmark numbers.
thanks,
~ dmytro
