Strange SPI Behavior
formica
Post by formica »
I observe a strange behavior traying to use the SPI on my custom board:
          cRPY_16bit[0] = 128;
          cRPY_16bit[1] = 128;
          cRPY_16bit[2] = 128;
          cRPY_16bit[3] = 128;
          cRPY_16bit[4] = 128;
          spiAcquireBus(&SPID2);                                             /* Acquire ownership of the bus.    */
          spiStart(&SPID2, &ls_spicfg);                                      /* Setup transfer parameters.       */
          spiSelect(&SPID2);                                                      /* Slave Select assertion.          */
          spiExchange(&SPID2,10,cRPY_16bit,rxbuf_16bit);         /* Atomic transfer operations.      */
          spiUnselect(&SPID2);                                          /* Slave Select de-assertion.       */
          spiReleaseBus(&SPID2);                                        /* Ownership release.               */
Watching the SPI Line with an oscilloscope I see the traffic IF the code above is compiled INSIDE an external thread, conversely it doesn't work IF the code is compiled in the MAIN THREAD (main function).
All the variable used are in the global scope.
Any ideas? Maybe it's a stupid things... in this case SORRY IN ADVANCE!
Re: Strange SPI Behavior
The parameter "n" in spiExchange() is not the number of bytes but the number of frames, 5 in your case. I don't know if the resulting stack corruption is the cause of your problem.
formica
Post by formica »
Thanks giovanni for your quick response. Also using your correction I obtain the same behavioe. The main thread doesn't communicate through spi. I'm chechking with the oscilloscope everytime.
It must be something specific in your setup, I tested SPI functions from the main function and found no obvious problems.
formica
Post by formica »
I discovered that the problem exists when, in the main thread, I use the serial-usb. It seems that SPI and SerialUsb cannot co-exist. If I move the spi in another thread... everything is ok. It sounds really strange! :|
No idea, but check the IRQ and the DMA priorites of both peripheral drivers. Maybe a problem source?
The thread makes no difference unless there is a stack overflow in the main thread.
Are you using CCM memory? if so make sure buffers are in a DMA-reachable area.
barthess
Post by barthess »
formica
What MCU you use? Did you enable all debug options in chconf.h?
formica
Post by formica »
I'm using an STM32F103RBT6!
I don't know what is a CCM memory (maybe an external ram). In this case... no, I'm just using a raw stm32f103rbt6 with some sensors on the I2C bus (gyro,acc,magn).
I attach the main file (with a lot of comments inside... It's a very dirty piece of code, sorry).
Now usb_write() and spi_write() are both in the main thread.
If you can, just take a look to the main function.
I observe that, if I read from the usb-serial ('sudo screen /dev/ttyACM0') the SPI works properly and I see the digital signal on the spi test_point. If I don't read from the usb-serial, randomly, it happens that the usb AND the SPI hangs up... while the led blink thread go on running properly.
Thanks in advance
Roberto
main.tar.gz
(4.99 KiB) Downloaded 578 times
formica
Post by formica »
My last version: I added a control on the USB_STATE.
As before, sometimes, when I don't read the USB from the terminal, the SPI hangs up.
Any idea?
systime_t time = chTimeNow();     // T0
  while (TRUE) {
   time += MS2ST(25);            // Next deadline
//   bmp085_read_temp();
//       bmp085_read_press(BMP_MODE_PR0);
   lsm303dlh_read_acceleration();
       lsm303dlh_read_magfield();
   l3g4200d_gyro_burst();
   complementary_filter();
   Roll_s=sign(Roll);
   Roll_e=exponent(Roll);
   Roll_m=mantissa(Roll);
   Pitch_s=sign(Pitch);
   Pitch_e=exponent(Pitch);
   Pitch_m=mantissa(Pitch);
   Yaw_s=sign(Yaw);
   Yaw_e=exponent(Yaw);
   Yaw_m=mantissa(Yaw);
cRPY_16bit[0] = (uint16_t)Roll_m;
cRPY_16bit[1] = (uint16_t)Pitch_m;
cRPY_16bit[2] = (uint16_t)Yaw_m;
cRPY_16bit[3] = (uint16_t)Roll_m;
cRPY_16bit[4] = (uint16_t)Pitch_m;
   spiExchange(&SPID2,5,cRPY_16bit,rxbuf_16bit);                 /* Atomic transfer operations.      */
   //spiSend(&SPID2,6,cRPY);
   if(SDU1.config->usbp->state==USB_ACTIVE)
      chprintf((BaseChannel *)&SDU1, "S:%6d:%6d:%6d:%6d:%6d:%6d:%6d:%6d:%6d:%6U:%6U:%6U:%6U:%6U:%6U:%6U:%6U:%6U:E\r\n",gyroX,gyroY,gyroZ,accelX,accelY,accelZ,magnX,magnY,magnZ,Roll_s,Roll_e,Roll_m,Pitch_s,Pitch_e,Pitch_m,Yaw_s,Yaw_e,Yaw_m);
   chThdSleepUntil(time);
