Page 1 of 2
Memory sections in linker script
Posted: Wed Apr 03, 2013 12:01 pm
by Laurent
Hi
I'm using a STM32F405 micro-controller, with its 192 KB of RAM. I need to get as much as possible from these 192 KB for dynamic allocations inside my program.
When I look at my linker script, I notice that two sections take a significant amount of RAM: ethram and ccmram.
MEMORY
flash : org = 0x08020000, len = 256k
ram : org = 0x20000000, len = 112k
ethram : org = 0x2001C000, len = 16k
ccmram : org = 0x10000000, len = 64k
My questions are:
- what are these two sections (I can't find any documentation about ethram, very little about ccmram)?
- can I safely remove them and merge the saved space into the "ram" section, getting true 192 KB of RAM available?
In case ethram is related to some ethernet stuff, I can say that I have no ethernet controller on my board.
Re: Memory sections in linker script
Posted: Wed Apr 03, 2013 3:21 pm
You can merge ethram but not ccmram because it is not contiguous. Note that the CCMRAM is not reachable from the DMAs, it is documented on the Reference Manual.
Posted: Wed Apr 03, 2013 3:28 pm
by Tectu
By the way, has anyone ever done some CCM benchmark? I'd be really interested to know if it works faster as well.
Posted: Wed Apr 03, 2013 3:31 pm
by Laurent
Any idea what the ethram and ccmram sections are normally used for? Can I use the ccmram myself, or is it used for some internal stuff? Is it faster than normal RAM?
Posted: Wed Apr 03, 2013 3:33 pm
The CCMRAM is not faster than normal RAM but it is not affected by DMA operations and that would translate in better performance on DMA intensive systems. You could allocate stacks there for example (there is an example .ld file for that for the F4).
Posted: Thu Apr 04, 2013 1:57 pm
by efuentes
What would be the best way to have space for variables allocated in the CCM instead of the SRAM?
Whenever I have done debugging, they have always been allocated in addresses greater than 0x20000000.
Posted: Thu Apr 04, 2013 2:18 pm
In ChibiOS there is an example .ld file that shows how to allocate arbitrary variables into the CCM memory: ./os/ports/GCC/ARMCMx/STM32F4xx/ld/STM32F407xG_CCM.ld
See this:
.ccm :
PROVIDE(_cmm_start = .);
. = ALIGN(4);
*(.bss.mainthread.*)
. = ALIGN(4);
*(.bss._idle_thread_wa)
. = ALIGN(4);
*(.bss.rlist)
. = ALIGN(4);
*(.bss.vtlist)
. = ALIGN(4);
*(.bss.endmem)
. = ALIGN(4);
*(.bss.nextmem)
. = ALIGN(4);
*(.bss.default_heap)
. = ALIGN(4);
PROVIDE(_cmm_end = .);
} > ccmram
Posted: Thu Apr 11, 2013 11:56 am
by Laurent
I added this to my linker script:
.ccm :
. = ALIGN(4);
*(.bss.my_var)
. = ALIGN(4);
} > ccmram
With
MEMORY
ram : org = 0x20000000, len = 128k
And, in one of my source files:
But my_var is not put in CCM RAM (its address is still 0x2000...). The only difference with the provided example is that it also puts .stacks in CCM RAM; however it crashes my app if I do so (some obscur error with SPI interrupts).
What am I missing?
By the way, if my_var is a buffer which is then written to a file on a SD card, it's not going to work anyway since it involves DMA, right?
Posted: Thu Apr 11, 2013 12:13 pm
Right, no DMA there.
Check in the .map file the section containing you variable and use that name in the .ld file for relocation.
Posted: Thu Apr 11, 2013 12:19 pm
by Laurent
One more question: if I only use the CCM RAM for one thing (like a single big buffer), can I access it directly by its address, without declaring anything in the linker script?
Like:
char* ccmram_ptr = (char*)0x10000000;
memcpy(ccmram_ptr , ...);
