Hang on STM32F4 Discovery and MAC driver
Posted: Mon Apr 15, 2013 8:37 am
by CheBuzz
I have an expansion board that is using the STM32F4 Discovery board to add an ethernet PHY and use the MAC driver in ChibiOS. Unfortunately the LIS302DL uses PA7 for MOSI, which is the only pin that can be used for RMII_CRS_DV so I had to remove the accelerometer. A basic LED blink code works just fine on the board. However, when I include the MAC driver in the code, everything hangs. I'm pretty sure it is hanging in halInit(). These are the pins I am using:
#define GPIOA_ETH_RMII_REF_CLK 1
#define GPIOA_ETH_RMII_MDIO 2
#define GPIOA_ETH_RMII_CRS_DV 7
#define GPIOB_ETH_RMII_TX_EN 11
#define GPIOB_ETH_RMII_TXD0 12
#define GPIOB_ETH_RMII_TXD1 13
#define GPIOC_ETH_RMII_MDC 1
#define GPIOC_ETH_RMII_RXD0 4
#define GPIOC_ETH_RMII_RXD1 5
All are listed as Free I/O in the STM32F4DISCOVERY datasheet (except PA7 as mentioned above).
Any ideas what the problem could be?
Re: Hang on STM32F4 Discovery and MAC driver
Posted: Mon Apr 15, 2013 12:50 pm
Is the PHY correctly clocked?
Posted: Mon Apr 15, 2013 1:06 pm
by Tectu
Did you set the PAL modes correctly? The halInit() fails when the PHY does not respond properly.
Posted: Mon Apr 15, 2013 5:07 pm
by CheBuzz
Giovanni wrote:Hi,
Hello Giovanni. Yes. I am using the KSZ8051 which takes a 25 MHz signal from a crystal/oscillator and then provides the 50 MHz reference clock to the MAC.
Tectu wrote:Did you set the PAL modes correctly? The halInit() fails when the PHY does not respond properly.
Yes, I am fairly certain I set the PAL modes correctly. Here is the board.h file so that you can verify just in case I am missing something: http://pastebin.com/XU4nLcBw
Posted: Mon Apr 15, 2013 5:17 pm
by Tectu
Are you using the embest expansion board?
Posted: Mon Apr 15, 2013 8:32 pm
by CheBuzz
No, I am using an expansion board that I designed myself. So hardware errors are not out of the question, but I am quite confident everything is routed correctly (verified with ohmmeter).
Posted: Mon Apr 15, 2013 8:36 pm
by Tectu
Now it's getting tricky ;-)
I don't really have the time nor the knowledge, but maybe you want to share your schematics for a review. Are you sure you didn't break the chip when soldering etc?
Posted: Fri Apr 19, 2013 5:49 pm
by CheBuzz
So just a quick update to this. I was missing a pullup resistor on the MDIO line, which appears to be what was causing the hang. I am also using the Micrel KSZ8051RNL PHY which does not appear to be supported in the ChibiOS MAC driver just yet. Some small modifications the ST library code (see http://andybrown.me.uk/wk/2012/09/01/ethernet-phy-stm32f107/) gets just about everything going. PHY is now being configured, but I am not yet able to ping it.
Posted: Sun Apr 21, 2013 12:50 pm
by ErikZalm
I also have a board with the KSZ8051RNL.
I use a external 50MHz osc. and have init the phy.
I made the following changes:
board.h
 * Ethernet PHY type.
#define MII_KSZ8051RNL_ID           0x00221550
#define BOARD_PHY_ID                MII_KSZ8051RNL_ID
#define BOARD_PHY_RMII
mcuconf.h
#define STM32_MAC_ETH1_CHANGE_PHY_STATE     FALSE
chconf.h (This selects the external 50MHz osc.)
#define BOARD_PHY_RESET() {                                                  \
          while (mii_read(&ETHD1, MII_BMCR) & BMCR_RESET);                   \
          mii_write(&ETHD1, 0x16, 2);                                        \
          mii_write(&ETHD1, 0x1f, (mii_read(&ETHD1, 0x1f) & 0x30) | 0x90);   \
Posted: Wed Apr 24, 2013 3:14 pm
by inca
For both users, where exactly does the code hang in the debugger? I had to enable the MAC (see my posts) earlier while it waited for information because otherwise the MAC would no longer clock, thus it would never get the data it was waiting for. It could probably have been solved with the various timing macro delays or timeouts, but none of the configurations I tested worked.
For reference, here was JerryR's post that fixed the issue for my KSZ8041:
viewtopic.php?f=2&t=733#p7380
