Standby and wakeup by RTC
Posted: Sat Apr 27, 2013 2:49 pm
stm32f205ve, chibios v2.5.1
Task is to enter Standby mode and wakeup once a second or so.
I used RTC wakeup example from testhal\STM32F4xx\RTC, namely RTC wakeup setup and func_sleep():
It works for first time only. I.e. after power up, CPU enters Standby, stays there 10 seconds, wakes, (does something), enters Standby - and does not wake up.
Power switch leads to repeat of the scenario.
I outputted RTC registers values, namely ISR:
When I put string
before
it started to work of properly. Namely, CPU wakes every time when expected.
It seems that WUTF should be cleared before setting up wakeup, it is insufficient to clear WUTWF only.
/* set wakeup */
wakeupspec.wakeup = ((uint32_t)4) << 16; /* select 1 Hz clock source */
wakeupspec.wakeup |= 9; /* set counter value to 9. Period will be 9+1 seconds. */
rtcSetPeriodicWakeup_v2(&RTCD1, &wakeupspec);
chSysLock();
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
PWR->CR |= (PWR_CR_PDDS | PWR_CR_LPDS | PWR_CR_CSBF | PWR_CR_CWUF);
RTC->ISR &= ~(RTC_ISR_ALRBF | RTC_ISR_ALRAF | RTC_ISR_WUTF | RTC_ISR_TAMP1F |
RTC_ISR_TSOVF | RTC_ISR_TSF);
__WFI();
- After PowerOn: 000027
After RtcInit(): 000007
After Wakeup setup: 000027
After Standby-and-wakeup: 000423
After RtcInit(): 000403
After Wakeup setup: 000427
When I put string
before
rtcSetPeriodicWakeup_v2(&RTCD1, &wakeupspec);it started to work of properly. Namely, CPU wakes every time when expected.
