Patch for USB
ChibiOS public support forum for topics related to the micro-controllers based on MIPS32 cores.
etmatrix
Patch for USB
Postby etmatrix » Thu May 02, 2013 5:15 pm
Hi Dmytro
Giovanni help me to resolve a problem with my project Dual USB CDC, with some patches. One patch has changed the usb_lld template and his test archictecture STM32. I replicated it on MIPS-PIC32. Could you submit in your repository?
diff --git a/os/hal/platforms/MIPS-PIC32MX/usb_lld.h b/os/hal/platforms/MIPS-PIC32MX/usb_lld.h
index 1d88784..b855762 100644
--- a/os/hal/platforms/MIPS-PIC32MX/usb_lld.h
+++ b/os/hal/platforms/MIPS-PIC32MX/usb_lld.h
@@ -274,6 +274,20 @@ struct USBDriver {
   const USBEndpointConfig       *epc[USB_MAX_ENDPOINTS + 1];
+   * @brief   Fields available to user, it can be used to associate an
+   *          application-defined handler to an IN endpoint.
+   * @note    The base index is one, the endpoint zero does not have a
+   *          reserved element in this array.
+  void                          *in_params[USB_MAX_ENDPOINTS];
+   *          application-defined handler to an OUT endpoint.
+  void                          *out_params[USB_MAX_ENDPOINTS];
    * @brief   Endpoint 0 state.
   usbep0state_t                 ep0state;
Thank you
Dmytro
Re: Patch for USB
Postby Dmytro » Thu May 02, 2013 6:37 pm
Hi Etmatrix,
It's clear that current HAL infrastructure is suffering from code duplication =/. Hope this gonna change with 3.0.
Anyway, I'll submit the patch, np.
regards,
~ dmytro
Has thanked: 1131 times
Been thanked: 944 times
Re: Patch for USB
Postby Giovanni » Thu May 02, 2013 7:12 pm
Code duplication? do you mean the common part of the driver structures?
Dmytro
Re: Patch for USB
Postby Dmytro » Thu May 02, 2013 8:00 pm
Giovanni wrote:Code duplication? do you mean the common part of the driver structures?
Yes, exactly. I tried to solve it in a non-intrusive way within current infrastructure. You may take a look at DMA driver.
cheers,
~ dmytro
Dmytro
Re: Patch for USB
Postby Dmytro » Thu May 02, 2013 8:29 pm
I merged the master and pushed correction for usb LLD.
BTW, seems likes os/hal/platforms/STM32/USBv1/usb_lld.h was not updated correctly. Also I see that most of the demos push USB driver instance to sduConfigureHookI.
Re: Patch for USB
Postby Giovanni » Thu May 02, 2013 9:30 pm
That's odd, I see them all updated and that low level driver has the new fields, revision 5657.
Dmytro
Re: Patch for USB
Postby Dmytro » Thu May 02, 2013 9:47 pm
Giovanni wrote:That's odd, I see them all updated and that low level driver has the new fields, revision 5657.
They all have new fields but os/hal/platforms/STM32/USBv1/usb_lld.h still has obsolete 'param' field.
Also demos/ARMCM4-STM32F407-DISCOVERY-MEMS/usbcfg.c and testhal/STM32F1xx/RTC_FATTIME/main.c still push usbp to sduConfigureHookI.
Re: Patch for USB
Postby Giovanni » Fri May 03, 2013 7:41 am
Thanks, fixed.
Return to “MIPS32 Support”
