serial_usb: supporting multiple instance
sam0737
Post by sam0737 »
I have patched the HAL serial_usb to support multiple serial_usb instance.
https://github.com/sam0737/chibios-rt-a ... c3300c5430
There is no breaking change to the user interface (old code should work as is), the changes are:
* remove the dependency from usbp->param
* User wishing to use multiple instance should specify the interrupt, tx, rx EP number in SerialUSBConfig
* An linked list is added to check/map the EP number of USB/Queue hooks to the device instance
I hope the patch is useful =)
Re: serial_usb: supporting multiple instance
Thanks for the patch however a fix for this problem has been committed last week :)
Looking at your code I realized that I didn't think to separate line coding, I will merge at least that part.
