Page 1 of 2
No rule to make target crt0
Posted: Fri May 24, 2013 6:37 pm
by idcavili
When I try to compile in Eclipse, I get "no rule to make target crt0.c." I have placed linked folders to the os and board folders but it apparently doesn't find them. Are there some more environment variables to set?
Re: No rule to make target crt0
Posted: Fri May 24, 2013 7:05 pm
There are no particular env vars to set except PATH.
It is most likely a problem with the toolchain, could you try ChibiStudio? it is a preconfigured Eclipse environment with all the latest components.
Posted: Fri May 24, 2013 8:51 pm
by idcavili
Chibistudio doesn't seem to download. Did it take forever for you as well?
Posted: Fri May 24, 2013 9:07 pm
It is on the sourceforge page, you can also select another mirror if I remember well. Choose one closer to you.
Posted: Sun May 26, 2013 4:26 pm
by idcavili
I got chibistudio and it still has this message. Perhaps I should start a new project.
Posted: Sun May 26, 2013 5:02 pm
Does this happen using one of the existing projects or a new project you created?
Posted: Sun May 26, 2013 6:57 pm
by idcavili
Existing.
Posted: Sun May 26, 2013 7:27 pm
Are you launching ChibiStudio using the provided link/batch or by launching directly Eclipse.exe? you should use the link, it sets required env variables.
Posted: Mon May 27, 2013 7:44 pm
by idcavili
Which project type should I select when starting a new one? I tried chibios and makefile project and neither of them come with the files pre loaded.
Posted: Mon May 27, 2013 8:31 pm
by RoccoMarco
Can I ask what platform are you using?
