arm_common_tables.h
Posted: Fri May 24, 2013 10:37 pm
Hey,
I'm making some tests with the CM4 DSP library and found that the various tables in the arm_common_tables.h file included in chibios are incorrect.
instead of
Was there a purpose for this modification ?
Reverting the file to the original one from ARM does fix the problem.
extern const uint16_t armBitRevTable[1024];
extern const q15_t armRecipTableQ15[64];
extern const q31_t armRecipTableQ31[64];
extern const q31_t realCoefAQ31[1024];
extern const q31_t realCoefBQ31[1024];
extern const float32_t twiddleCoef[6144];
extern const q31_t twiddleCoefQ31[6144];
extern const q15_t twiddleCoefQ15[6144];
instead of
extern uint16_t armBitRevTable[1024];
extern q15_t armRecipTableQ15[64];
extern q31_t armRecipTableQ31[64];
