External Interrupt Handler
Posted: Tue Jun 25, 2013 11:01 am
by donmichael
Hi
Which is the best way to write interrupt handlers? [External Interrupt]....It seems we can specify a call back function in driver configuration or we can use CH_IRQ_HANDLER with required vector name. What is the difference between these two? and It seems CH_IRQ_HANDLER is disabled in main.c file... What could be the reason? I'm using STM32VL discovery with default board files..
Thanks in advance.
Re: External Interrupt Handler
Posted: Tue Jun 25, 2013 11:21 am
hi,
If you need to handle external interrupts you can use the EXT driver and not have to write any interrupt handler.
If you want to write an interrupt handler then CH_IRQ_HANDLER is the way to go, I don't understand what you mean with "disabled in main.c", if you include ch.h then the macro is available.
Posted: Tue Jun 25, 2013 11:39 am
by donmichael
Dear Giovanni,
The code that I tested is some thing like this.
static void button_handler(void)
///doing the handling.
// Channel configuration.
{EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, button_handler}, /* 0 */
{EXT_CH_MODE_DISABLED, NULL}, /* 1 */..................
And then in main I call
// Activate first EXT driver.
extStart(&EXTD1, &extcfg);
This works just fine..
But when I try to write it with
#include "ch.h"
CH_IRQ_HANDLER(EXTI0_IRQHandler)
{EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, CH_IRQ_HANDLER}, /* 0 */
the compiler gives error:
'CH_IRQ_HANDLER' undeclared here ( not in a function).
Chibi documentation recommends to use CH_IRQ_HANDLER any way.
Is it okay to use handler like this?
Posted: Tue Jun 25, 2013 12:44 pm
No because the EXT driver declares that handler internally, so you use the EXT driver OR write the handler yourself.
