Backup SRAM
Posted: Tue Jul 16, 2013 5:52 am
I'm trying to use the Backup SRAM, the one located in the Backup Domain, at 0x40024000, (BKPSRAM_BASE), and I'm quite confused about how to go about it. This is on a STM32F4 (custom board) with working RTC on backup battery (CR2032).
I see that hal_lld_init() calls hal_lld_backup_domain_init(), but nowhere does it enable the BKPSRAM, as specified in the Reference Manual (RM0090, Rev4), section 5.1.2, page 91, "Backup domain access". It says:
-Enable the power interface clock by setting the PWREN bits in the RCC_APB1ENR register
-Set the DBP bit in the PWR power control register (PWR_CR)
-Enable the backup SRAM clock by setting BKPSRAMEN bit in the RCC AHB1 peripheral clock enable register (RCC_AHB1ENR)
The function hal_lld_init() enables the power interface by calling "rccEnablePWRInterface(FALSE);" then the function hal_lld_backup_domain_init() sets the DBP bit (PWR->CR |= PWR_CR_DBP;), but the BKPSRAMEN isn't set, and therefore all access to the BKPSRAM returns 0's. If I set that bit, but calling this:
RCC->AHB1ENR |= RCC_AHB1ENR_BKPSRAMEN;
Then I can access the contents and save things, and everything works across resets.
But if I remove main power, its contents are lost. The debugger shows all 0's again until I set the BKPSRAMEN bit, where the contents are again random values.
I'm also writing out data to the RTC->BKP0R registers - magic number, configuration version and checksum of the BKPSRAM contents, and those values are intact after power removal.
Any clue as to what is going on?
