DAC problem!
M.H.Roohi
DAC problem!
Post by M.H.Roohi »
Hi all
i tried to compile DAC library (by Mobyfab) but i found lots of errors.
LINK: https://github.com/mobyfab/ChibiOS/tree/dac
and finally i found out that dac_lld.h and dac_lld.c and dac.c are not match
for example i found the following code in dac.lld.c
_dac_isr_error_code(dacp);
and the following code in dac.c
#define _dac_isr_error_code(dacp, err)
could anybody please help me about that or introduce me another way?
THX
Re: DAC problem!
The driver made by mobyfab is different from the half done driver in the repository, you need to replace dac.c and dac.h taking them from mobyfab work.
M.H.Roohi
Re: DAC problem!
Post by M.H.Roohi »
I download them took them from mobyfab work, from following link
and the dac.h was there, witch directory do you mean?
M.H.Roohi
Re: DAC problem!
Post by M.H.Roohi »
i mean : os\hal\include\dac.h
Re: DAC problem!
Correct, you have to replace .\os\hal\include\dac.h and .\os\hal\src\dac.c.
M.H.Roohi
Re: DAC problem!
Post by M.H.Roohi »
i used mobyfab sources and in already in os\hal\include and src are dac.h and adc.h file
what should i do? reaplace them with wath?
Re: DAC problem!
I thought you wanted to use mobyfab driver with the official distribution, if you are using mobyfab tree as-is you don't need to replace anything I think.
M.H.Roohi
Re: DAC problem!
Post by M.H.Roohi »
So, what can I do with those error?
is there any other solution for using dac with chibios?
or can you send me a compiled dac demo code of mobyfab?
Re: DAC problem!
Try to PM mobyfab he is always very helpful, you may also try the #chibios IRC channel: http://www.chibios.org/dokuwiki/doku.ph ... nline_help
mobyfab
Has thanked: 21 times
Been thanked: 31 times
Re: DAC problem!
Post by mobyfab »
Hey,
I will try to update the code to work with the current version on Chibios.
Just check for updates in my repo.
